ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 02-01-2000, 09:28 PM
markmartinbirdie is an unknown quantity at this point
Default Tricked Up Sidekick/Trac Anyone got one?
I am considering tricking out a Sidekick/Tracker. Does anyone know of anyone who has one or some
pictures of one. How much lift can I get out of one? Thanks
Old 02-02-2000, 11:29 AM
Default Re: Tricked Up Sidekick/Trac Anyone got one?
I've seen a few lifted and locked kicks/trackers, not many though. I think the max suspension lift you can get on one is about 2inches, Glenn also has some coil spacers which give somthing like an extra one inch lift. This is keeping the stock IFS too. I think you can put 30 inch tires on with minor rubbing. 29inch tires should fit fine I think(don't have a kick to play with here so this isn't from experience)
There have been a few people that have swapped solid axles under these things too, that'll give you more lifting options, but probably a little expensive. I haven't seen any of these pictures on the net, but I'm sure there are a few out there, I do recall seeing one in a mag at some point.
Calmini has a pic of a lifted zuk, also Rocky Road has a pic of two Sidekicks with OME 2inch lifts.
Good Luck
Mike Schramm
88 Sammy in the garage
Old 02-03-2000, 05:33 PM
Dude
Suspension wise you can go for the procomp 2.5" lift kit, 2" kit from calmini & 1.5" from OME
Body lift - 3" will clear 33s with minor to modrate fender trimming depending on the tyre width & wheel offset.
LA Super Trux can supply you a full body lift ( you need their special sleeved bolts )
they also do a geometry correction kit for the procomp lift.
E-mail them on .... lasupa@aol.com
For ultimate kit Jim Mazolla is trying to go ahead with a fully bolt on 6" suspension kit.
E-mail me .... rhinosaur@fourplay.org.uk for pics of 33'd 4door & 2door sidekicks.
e-mail me on.... jnunespe@genre.com for jim mazola's e-mail addres if interested.
Going 31s plus you'll need to gear down
Joe
Old 09-09-2009, 12:21 AM
Newbie
Suzebraki is on a distinguished road
Default
I have 31s with stock suspension and barely get any rubbing...
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
