OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 03-28-2003, 10:15 PM
racegt6
Default Battery dies
My battery dies completely when the Sami sits for 4-5 days. Newer battery and will check it tomorrow but looking for a heads-up in basic troubleshooting. If the battery checks out ok, I assume a short in a hot circuit. How can I isolate? If battery is disconnected an I take an Ohm meter from the fuses to ground? OR....? Thanks, Charlie
Old 03-28-2003, 11:01 PM
Carpal \'Tunnel
Sarge is an unknown quantity at this point
Default Re: Battery dies
If you can't find a parasitic drain , there is a way to test for it . You can hook up a meter inline with the positive side battery cable , if it shows voltage there is a drain . Take the fuses out one by one , that will show you what circuit it is . If there is no drain in the system , check the battery out . If the battery has removable caps , take them off and connect the meter to the negative side of the battery . Starting at that end of the cells , probe down into the acid in each one with the positive test lead from the meter , each cell should progressively go up 2 volts , ie: 2,4,6,8 ect.. ., until reaching 12 at the other end . If any one cell does not increase the voltage , that cell is dead and will drain the battery in a very short time . Most testers in Auto stores won't show that , they will take and hold a charge somewhat , but can't provide full power or hold a charge for any length of time . If it's a sealed unit , no test like that can be done . Hope this helps,
Sarge
Old 03-28-2003, 11:48 PM
racegt6
Thanks, but not certain what you mean about hooking up a meter in-line on the positive cable. Do mean both probes go into the b+ cable? Does it matter where? Thanks, Charlie
Old 03-29-2003, 05:58 AM
Mini4x's Avatar
Mini4x is an unknown quantity at this point
unhook one of the cables and put one end of the meter on the cable end and the other on the battery post.
Search this Thread:
Advanced Search
Need Gas Mileage & Power?-
Off-Road Videos -
ATV Reviews -
