White valves? What now? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 03-28-2003, 05:25 PM
Journeyman
diymobilesound is an unknown quantity at this point
Default White valves? What now?
I tore the head off my 16V to fix a stripped spark plug hole (don't ask, this thing is cursed) to find 3 white valves. I attached a picture. What does this mean? The vehicle was running bad and I thought it was some bad plug wires after driving it without coolant and overheating the motor (don't ask). Any guesses? [img]images/graemlins/cussing.gif[/img]
Old 03-28-2003, 06:29 PM
Journeyman
Default Re: White valves? What now?
Forgot to upload pic...
Old 03-28-2003, 06:53 PM
I think it is the coolant when overheating...
You should clean all of this and check if everything is straigt...
Old 03-28-2003, 07:59 PM
OLDCODGER's Avatar
OLDCODGER is an unknown quantity at this point
Don't know ~But wish I had that many valves!!!!
  #5
Old 03-28-2003, 11:19 PM
Journeyman
A buddy of mine says it could be a burnt valve but they still open and close fine. Is this true?
  #6
Old 03-28-2003, 11:34 PM
Sarge is an unknown quantity at this point
You're two center cylinders are blowing oil , mostly looks like the rings , could be the valve guides or seals . Check the guide seals under the springs to see if they are cracked or blown off . The two end cylinders are semi-burnt , it's either running lean on those two or you really got it hot . Is the head warped ? It should be , judging by the way it looks . I'd bet the ends are raised at least .004" each or worse . Once you fix the head , I'd go looking for the reason it's showing lean on the end cylinders , and the oil problem in the center . Could be nothing more than a plugged pcv blowing the valve guide seals off from crankcase pressure .
Sarge
  #7
Old 03-29-2003, 01:47 AM
Journeyman
Oh great.. More problems.
  #8
Old 03-29-2003, 08:29 AM
RRich is an unknown quantity at this point
The white deposit looks like it's a gasoline addative, notice it scapes off. Shell gas tends to do that quite a bit but others do too.
If it's not burned and seals fine I'd use it.
The center ones are oily, the white deposit doesn't stick to it as easy.
As mentioned, check if the oily is from the PCV system.
  #9
Old 03-29-2003, 09:33 AM
Nowhere's Avatar
Nowhere is an unknown quantity at this point
Could the valves and valve seals (preventative maintenence) be replaced and the head checked for straightness and call it quits?
  #10
Old 03-29-2003, 10:06 AM
Journeyman
With the amount of money I've spent on this thing I'm thinking of selling it and calling it a day.. What a PITA.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
