| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Suzuki GEO All Discussion of all things, Suzuki and GEO |
03-26-2003, 10:46 PM
| | | PTO on a Tracker? Is it possible to somehow rig up a front mount pto on my 94 Tracker? My dad is buying it from me to use around the farm, and we were thinking that it would be awesome if we could somehow have a pto to run a grain auger from. Even if it was out the rear that would be fine. Has anyone ever attempted something like this? |
03-27-2003, 10:56 AM
|  | Pooh-Bah | | | Join Date: Sep 2001 Location: eureka ca
| | Re: PTO on a Tracker? the only thought i would have would be a hydrolic drive pto it would probably require a v belt driven pump and i dont know if it would have the space (i doubt the power steering pumps would be up to the task)or maybe somthing could be rigged up off a vebelt and a hand controled tentioner like the old rototillers |
03-27-2003, 12:32 PM
| | Enthusiast | | | Join Date: May 2001 Location: Lanark, Ontario
| | Re: PTO on a Tracker? TracKick platform was never set up for PTO.
Samurai/SJ platform was although you can't get the parts in North America.
So, short answer is you are SOL.
r@m |
03-27-2003, 12:51 PM
|  | Pooh-Bah | | | Join Date: Dec 2001 Location: Atl, GA
| | Re: PTO on a Tracker? i have seen some where where they took a york compressor mounted in side the cab and mounted a pully the drive shaft from the motor to the t/case so if they wanted to use the air they could put it in neutral and let the motor idle. they did not say anything about this but i think it would only work for off-raod because highway speeds would be to much for the compressor and it would be in the passenger side floor i guess
so i guess you could do this with a pto pump from notherntool.com if you did not want to put it up front
90.00
BARNES High Pressure Hydraulic Gear Pump
Use it on mobile equipment, construction and agricultural equipment, machine tools, material handling and mining equipment, PTO pumps, refuse haulers, compaction and baling equipment. Standard 4-bolt mount. 1.78in. diameter pilot with 1/2in. x 1 1/2in. shaft, 1/8in. square key. Heavy duty cast iron pump turns at 4000 RPM max. in CW or CCW direction. Use as a fluid pump or fluid motor. Similar to Parker D Series, Webster YB Series, Rexroth S12, MTED Series. Flexible coupling or belt (pulley) drive. 95% efficient. U.S.A. |
03-27-2003, 01:19 PM
| | | Re: PTO on a Tracker? OK So what you guys are suggesting with the hydraulic pump, is to mount a pump on the engine to run off the belts, and then mount another on the front or rear of the Tracker using the hydraulic power from the engine mounted to run the one on the front... I get it, and I think it would be easy enough to do! Thanks for the help, I don't know why I didn't think of hydraulics! |
03-27-2003, 01:21 PM
| | Re: PTO on a Tracker? on a rig with a divorced transfer case this would be possiable but the tracker / kick it is a married case (wont work) |
03-27-2003, 01:33 PM
|  | Carpal \'Tunnel | | | Join Date: Mar 2001 Location: Altamonte Springs FL
| | Re: PTO on a Tracker? I dunno about that belt drive hydraulic system. Is it possible to have a 40HP belt driven hydraulic system? Seems the smaller hydro pumps would not have enough oomph/GPH @ a certian psi to work well?
[img]images/graemlins/laugh.gif[/img] |
03-27-2003, 01:38 PM
| | Re: PTO on a Tracker? only one
something like this
at the motor this is only the pump part you need the thing that turns from the flow
you should need a tank for the fluid, if you want to go forward and reverse you would need control valve like whats on a log spliter
i could not find the head unit sorry
remember it would run around 3600 rpm over 4000 and you would burn up the pump and bearings |
03-28-2003, 10:28 PM
| | Newbie | | | Join Date: Sep 2000 Location: fredericksburg, va
| | Re: PTO on a Tracker? What if you put a sami t/c behind the tracker t/c, and ran the pto off of the tracker front output? | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:12 AM. |
