| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Suzuki GEO All Discussion of all things, Suzuki and GEO |
03-27-2003, 12:33 PM
|  | Veteran | | | Join Date: Feb 2001 Location: Minnesota
| | Re: who runs calmini fronts?? i agree with silverzuk. calmini is famous for advertising products that are not in production or else they promise that "in the near future" they will have the product ready.
did they have the duel webber intake manifold for a gti head that was advertised for sale for many many years in their catalouge??? yes, they made a prototype but never released it for sale to teh public. bummer for me.
however, if this product is actually in existance, which it may well be, i would not hesitate to guess that the quality would be second to none, like the rest of their product line.
as for breakage, i would prefer mine to happen as close to the hub as possible, to simplify repairs. |
03-27-2003, 01:49 PM
| | Old Hand | | | Join Date: Dec 1999 Location: Santa Rosa,CA USA
| | Re: who runs calmini fronts?? The Calmini front shafts are in stock,I got a set several
weeks ago.As far as breakage occuring next to the diff,these
shafts solve that problem.Having a larger spline count and
being made of a stronger material the weak point will be
forced out to the Birfield again,probably even with rings
or the Longfield modification.
I've got no experience with Longfield Samurai Birfs so
maybe somebody who does can fill me in.Figmo used to sell
these so there must be some in use.On the Toyota versions
they weld a ring on,is this done on the Samurai Birfields?
Seems like there wouldn't be any room in the knuckle.
Are the inner races heat treated (softened)like the outer
cup of the Birfield? If not then that will most likely be
the weak link. |
03-27-2003, 04:27 PM
| | Enthusiast | | | Join Date: Sep 2002 Location: Seattle Wa, USA,
| | Re: who runs calmini fronts?? The longfield birfs for zuks won't have the ring welded on, neither will toyotas, this is due to turning radius (i mentioned this already). The inner cage and the outer stub and birf is ALL treated with the same process. With calmini the shafts are larger and are 26 spline, they are the same diameter as the rear axle shafts made by calmini, they are 4140 cromoly, that will be a MUCH bigger increase in strength. Also you could run warn hubs with the lighter weight fuses. I will ONLY be running 34-10.5 ltb's with this setup, and BARELY any rock at all. So I guess we will see!! I am gonna say this will hold up fine. [img]images/graemlins/40BEER.gif[/img]
Scott |
03-28-2003, 11:18 AM
| | | Re: who runs calmini fronts?? Not calmini, but i do have the Trail Tough Double Tough axles in the front end of my zuk...for over two years now. About 15 trips to Uwharrie, and a trip to Globe, and a trip to zukimelt, where i rolled [img]images/graemlins/40BEER.gif[/img]. Not to mention I have broke three drivers side rear axles in the same time period...later, aaron |
03-28-2003, 09:59 PM
| | Re: who runs calmini fronts?? Do you have the old version double toughs or the newer version? The old version I have been told just used rear axle shafts, not the cromoly shafts. I have heard good reports from everybody who runs those. I think the longfield/calmini would be about as strong as the double toughs. You might want to look in to a set of the calmini rear axle shafts. I have heard all good reports about those and 33's. I think longs/calmini should do me good especially since I'm not much into rocks.
Scott [img]images/graemlins/40BEER.gif[/img] | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:58 AM. |
