ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 01-03-2000, 03:40 PM
Default how wide on stock rims
What is the biggest tire I can put on a stock rim.
Old 01-03-2000, 07:22 PM
88.5 Samurai's Avatar
88.5 Samurai is an unknown quantity at this point
Default Re: how wide on stock rims
I have seen 31 x 10.50's on stock rims (15 x 5.5) but it didn't look safe to me. I ran 235/75's on stock rims with no problems. A friend of mine ran 30 x 9.50's on stock rims for a couple of years with no problems.
Old 01-03-2000, 08:12 PM
I know a guy that ran 31x10.5's and dropped them to 5psi when wheeling. Worked fine. The problem you will have, especially if you get any kind of aggressive tread, is the tires will rub the springs when you turn. I run 31x10.5 mud's on 15x7's and have no rubbing. HTH.
Old 01-03-2000, 09:27 PM
CSR's Avatar
CSR CSR is offline
CSR is an unknown quantity at this point
I have 30x9.50's on one of my Zuks, mounted on reversed stock wheels. I've seen 32x9.50 Swampers on stock wheels, but they were also reversed.
<font color=green>Happy Trails,</font color=green>
crobbins@iswt.com [img]/wwwthreads_images/icons/cool.gif[/img]
  #5
Old 01-03-2000, 10:05 PM
monty
Inturder , what is the back spacing on your 15x7 wheels ?
And CSR how far out does the tyre stick with a 30x9.5 on a reversed rim stick from the body ? Saves me buying a tyre to find out .
Thanks Monty again .
  #6
Old 01-03-2000, 10:07 PM
Backspace is stock, 3-1/2 inches I think.
  #7
Old 01-03-2000, 10:27 PM
CSR's Avatar
CSR CSR is offline
The tire sticks out past the fender flare about 1"/1.5". The older style wagon wheels are the ones I have. I don't think you can reverse the later style with the round holes.
  #8
Old 01-04-2000, 08:25 PM
oldfartzuk is an unknown quantity at this point
I just installed a set of roadmaster 30 X 9.5s on my Zuk with a calmini 2" reversal lift & doetsh shocks on stock white wagon wheel rims..... NO RUBBING ANYWHERE.
oldfartzuk on South Carolina coast....
donray
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
