Samurai Timing Problems - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 06-09-2002, 08:59 PM
Default Samurai Timing Problems
Hey all,
Last week, I performed a tune-up on my '87 Samurai and set the timing to 10 degrees BTDC after adjusting the idle to 850rpm per the factory instructions. The Sammy ran great for several days until I noticed that the idle had jumped up to 1100rpm and there was now excessive "pinging" during acceleration.
I rechecked the timing and was surprised to see that the 10 degree mark had advanced enough to no longer be visible through the timing window. I corrected the timing and for the next several days, the Sam ran like new with little or no "pinging."
Today, I noticed that the excessive "pinging" was back and that the idle had moved back up to around 1100 rpm. I checked the timing and again, it had somehow advanced itself. I checked my distributor hold-down bolt and it was tight. I checked the tension on the timing belt which was also within spec. What could be causing this problem?
Thanks. John
Old 06-09-2002, 09:06 PM
dparker's Avatar
dparker is an unknown quantity at this point
Default Re: Samurai Timing Problems
only 2 things i could think of timing belt streching , or your springs and wieght in your dist are wore out
Old 06-09-2002, 09:29 PM
IMC2112
Check you cam gear. If it is a steel gear, the slot where the locating pin maybe elongated/oversize.
Philip
Rotational Dynamics
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
