ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 12-29-2001, 09:30 PM
lilsami88's Avatar
lilsami88 is an unknown quantity at this point
Default Cam
How do you know if your cam shaft goes out. I think mine might have. When you turn the truck over the starter will crack once or twice then grab. theres no compresion when you try to jump start it. any one have this happen
1988 Zuk 2 in shackles 31x10.5x15 on stock rims stock gears
Old 12-29-2001, 10:02 PM
dparker's Avatar
dparker is an unknown quantity at this point
Default Re: Cam
give us a couple more detals . is it just only turn over twice and locking up or is it just hard to turn over ?do a comprision check . pull timing cover belt and check the belt i would suspect more of a timing jump or belt braking ,
when did all this start?
and yes if you dont no it buy now i cant spell LOL!
Old 12-29-2001, 11:06 PM
lilsami88's Avatar
Default Re: Cam
Well it only started once and it hardly ran i had to put the gas pedel to the floor and it wouldn't go over 2 rpms. yea after you crack it once or twice it locks up. i was thinking it was the head gasket but theres no oil in the anti-freeze.
Old 12-29-2001, 11:09 PM
dparker's Avatar
Default Re: Cam
sounds like timing to me check see if your timing marks still line up. win did it start doing this?
  #5
Old 12-29-2001, 11:20 PM
lilsami88's Avatar
Default Re: Cam
It started about a week ago when i was driving down the road. it just lost all power and after it stayed running for a few seconds it quit.
  #6
Old 12-29-2001, 11:34 PM
dparker's Avatar
Default Re: Cam
yeah pull your timing cover and check it
  #7
Old 12-30-2001, 12:08 AM
lilsami88's Avatar
Default Re: Cam
ok i pulled the cover off to the point where i could push on the belt and it moved in about 3/4 of an inch i'm guessing it should be tight. so should i asume this is it and start breaking down the front of the motor. what all do i need to do to realine it.
  #8
Old 12-30-2001, 12:59 AM
Default Re: Cam
Remove the shroud, remove the fan, belts, pully, crank pully, timing cover. And yer there.
Sounds like the tensioner may have broken. There is a spring activated tension plate with a tab that prevents it from moving out of alignment. This can break and and you'll lose all tension. Or it could have come loose, broken tensioner, or spring.
Happened to me on the trail once, but I was able to fab that tab with a 70 amp arc welder, and it lasted the life of the engine.
Neal the Zukiguy
  #9
Old 12-30-2001, 04:26 AM
zukikid
Default Re: Cam
why you are in the go a head and replace timing belt...check tentioner for side to side movment.
wow ...it still fits out the garage !!!!
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
