ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 12-28-2001, 12:33 AM
CrowHorse's Avatar
Carpal \'Tunnel
CrowHorse is an unknown quantity at this point
Default Winter Temps & Running Too Cold ??
I'm running a 180 degree thermostat (new) and with the winter temps that have gripped us here in the NE, while on the highway the temp barely makes it to 160-165 degrees. At first I thought a 195 thermostat would be the answer, but thinking again, if the cooling air at highway speeds cools so much not allowing it to come up to proper temps, a higher thermostat wouldn't resolve this. Am I correct in this? I'm running an electric fan.... Around town, engine temp runs around 180......
I really noticed a big drop in temps after replacing the heater core with a new one........
All Good Medicine,
Crow
Old 12-28-2001, 12:43 AM
DaveAZ is an unknown quantity at this point
Default Re: Winter Temps & Running Too Cold ??
go with a 195, it will allow the water to get warm enough while it is in the motor....it is the answer and will rosolve your trouble.
Dave
Old 12-28-2001, 03:25 AM
dparker's Avatar
dparker is an unknown quantity at this point
do like i do crow put a piece of cardboard in front of raditor on those real cold days that well keep it at right temp
and yes if you dont no it buy now i cant spell LOL!
Old 12-28-2001, 07:45 AM
guyina4x4's Avatar
guyina4x4 is an unknown quantity at this point
go with a 195
that's the temp when it opens, meaning it will most likely run in the 180-185 range, much warmer on the feet.
scott
90 Suzuki Samurai
90 Isuzu trooper
67 14' Richline
  #5
Old 12-28-2001, 10:27 AM
RamblinZuk is an unknown quantity at this point
Crow, gotta go with dparker on this one. Put a piece of cardboard in front of the radiator. This will block off a lot of that cold air that's keepin' the temps down.
Larry Robertson
88.5 Samurai-Under construction-always
90 Samurai-Under construction-always
Way too much horsepower is barely enough!
  #6
Old 12-28-2001, 10:43 AM
Farther is an unknown quantity at this point
The answer is to move from the NE to the NW.
-Farther
  #7
Old 12-28-2001, 11:49 AM
CrowHorse's Avatar
Carpal \'Tunnel
Actually, I do plan to move southwest....very south west....NZ!
All Good Medicine,
Crow
  #8
Old 12-28-2001, 01:56 PM
cardboard will work, i used to do that in my Camaro when i lived in NY, just don't forget to remove it before wheeling, and when Spring comes, you don't wanna overheat...
ROACH Da NastyPimp[img]/wwwthreads_images/icons/wink.gif[/img]
88.5 Zuk Calmini header/GRS1/235MT/Lock Rite/Centerforce stage1[img]/wwwthreads_images/icons/wink.gif[/img]
  #9
Old 12-29-2001, 02:31 PM
CrowHorse's Avatar
Carpal \'Tunnel
The 195 thermostat did the trick!!! Thanks guys!
All Good Medicine,
Crow
  #10
Old 12-30-2001, 11:06 AM
you are welcome...even here in Arizona, we have times when we need more heat....not too often though.....
DaveAZ
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
