ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Subaru All
Subaru All Disccussion of all topics on Subaru AWD and 4WD vehicles
Old 01-10-2000, 05:16 PM
Default OHC Timing
I have an 85 1800 OHC engine and I (surprise) thrashed another set of head gaskets. Anyway, I forgot the secret Subaru Ninja magic for sting the cam timing. I set the engine at TDC and aligned the timing mark on the driver side cam with the notch in the plastic cover. Then I rotated the motor 1 full turn, alinged the timing mark on the driver side cam with the notch in the cover and put it all back together. My valves aren't hitting pistons but my motor will not start. I remember something about the three hash marks in the flywheel and I think that's the trick, but I don't remember the exact details.
Old 01-10-2000, 10:59 PM
Default Re: OHC Timing
I've installed belts on my '86 a couple times. I have 2 different manuals, they both are different and complicated. I talked to a Sub mechanic and he gave me these directions: Align center of the 3 flywheel marks (lll) with notch, set drivers side cam dot to up notch and passenger side cam dot down. This works, you don't have to worry about TDC. Do you have a tool to tension the belts? Ed.
Old 01-11-2000, 06:02 PM
I just use a BAPB (big a$$ pry bar) or my hands to tension them. Of course, I did loose a timing belt to to much tension 7 months ago.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride.
