ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Subaru All
Subaru All Disccussion of all topics on Subaru AWD and 4WD vehicles
Old 09-12-2002, 02:38 PM
Default OVERHEATING, new radiator & thermostat no help!!!
I have a 1988 GL Wagon 4WD, with an automatic tranny. It boiled over one day going up a mountain pass, and continued to get extremely hot under normal conditions. I had several mechanics look at it, and they recommended replacing the radiator. I took their advice and put in a brand new Napa radiator and new thermostat as well. BUT, it is still overheating!! What's up? I thought it could be the water pump, but again, I've had mechanics tell me it would be loud and noisy, and would be obvious. I haven't heard or noticed anything unusual, so WHAT IS GOING ON???? PLEASE HELP! Thanks.
Old 09-14-2002, 12:18 AM
AJMBLAZER's Avatar
AJMBLAZER is an unknown quantity at this point
Default Re: OVERHEATING, new radiator & thermostat no help!!!
Cracked cylinder head?
Old 09-18-2002, 09:01 PM
SteelyDel
Check fan thermo switch and electric fan if it's in good working order. I have dual fans in my Brat. All Subarus have an additional space on the radiator for 2nd elec. fan.
Check sending unit it may be fooling you also.
Del
Old 12-20-2002, 08:35 AM
Pooh-Bah
rangerrick is an unknown quantity at this point
I would insure the fan works and even install an extra fan.Next I would do a radiator pressure check to see if you have a bad head gasket or cracked block/head.Last,if your engine got real hot ,you might have warpped you head.RR
  #5
Old 10-21-2003, 05:21 PM
I had a 93 Imprezza that was overheating and running hot all the time. I changed the radiator cap and haven't had a problem since ( 4 years). I hope you changed yours as well.
  #6
Old 09-14-2005, 08:32 PM
tincan is an unknown quantity at this point
check for hoses that collaspe,,,the suction side of the pump will collaspe at speed when the get old.... check for slipping belts,,,check for clogged exhaust...
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
