Piston damage from breathing snow? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Snowmobiles and Sledding > Snowmobile Lounge
Old 03-15-2001, 10:48 PM
Default Piston damage from breathing snow?
I've heard people say that if an engine sucks snow it could damage the pistons on the intake skirt. That seems reasonable to me, but is that what happens in the real world?
How do all of you powder riders deal with breathing snow?
I just pulled apart my 650 and found all of the pistons badly scored on the intake skirts (one broken off). One of the "good" pistons measured .25mm narrower skirt to skirt than at the top of the piston.
There was a day about 4 years ago when the motor breathed serious amounts of snow and I'm wondering if that's what caused/contributed to the problem.
Steve
1990 Indy 650 (in pieces all around my garage)
Steve S.
http://home.off-road.com/~ovo/members/sshaw/sshaw.htm
Old 03-15-2001, 11:41 PM
portgrinder
Default Re: Piston damage from breathing snow?
all of my sleds have sucked in a-plenty and nothing's went wrong
You wear your silver chain but the cross won't stop the lies,you believe in nothing
Kenton Thomas,Portal
Old 03-16-2001, 01:06 AM
depends on type of snow if its powder you can just clean it off now and then but watch out for that hard packed stuff i have seen that stuff do the job before.
Old 03-16-2001, 12:52 PM
I haven't seen any damage due to snow injestion usually they just run like crap until you get them cleaned out; but we do go to great lengths to keep filter foam or screens in place to prevent it from getting into the carbs. We have tried socks but found that wasn't good enough on the newer machines, they need air piped in from outside of the engine area and the stock air boxes do the best job of that. They also limit how much snow goes right into the motor. I would stay with the stock air box on your 650 and maybe add apiece of course foam under the plate in the hood, I bought a piece off of a 99 700 and cut it down to fit. If it gets plugged, I pull it out and bang it against something to clean it out the put it back in.
If you mic a new piston you will find it is actually cone shaped. The rings hold it centered in the bore at the top but the skirts have to hold it centered at the bottom. The engine manufacturer calculates how much the piston will exspand when hot, adds about .003 for the oil film and that is his bore spec. When the skirts wear they start to bang back and fourth in the bore until a skirt breaks off. I'm not sure how much narrower the top is than the skirt so check a new piston if you want to know.
  #5
Old 03-17-2001, 01:12 AM
What surprised me about the pistons in my sled is they were galled on the intake side as if the engine had partially seized previously. When I measured them they were actually smaller in the piston skirt area, not larger as they are supposed to be.
I do have a foam filter on the top of the airbox that filters snow (and plugs up, required banging out when running in very deep snow). For some reason though, Polaris decided to install a simple unfiltered tube on the right hand side of the air box that leads up to near the handle bars. This side sucks snow directly into the air box.
One day about 4 years ago I got caught in an insane blizzard with around 5' drifts and cold temperatures (-25°ish not counting the 60 mph winds). The drifts were so tall that I basically was driving through them. I eventually ended up getting lost in the white out and the sled started really acting up (stalling constantly - very difficult to start). At first, simply banging out the filter would get me going again, but after a while the carbs started to individually seize wide open with ice buildup. Another problem as night settled in was each time I plowed through a drift my headlight got packed with snow. At one point I couldn't get the engine going again, so I pulled the top off the airbox and found it was practially full of snow - with the snow entering throught the right hand tube. I cut the tie wrap that holds the tube to the handlebar area and left it hanging under the hood (hoping less snow would get in). I eventually got the thing running again and it did work better. Eventually I made it home. With the engine acting up so badly I also got stuck about 20 times and was totally exhausted (actually the experience was quite scary - at one point the sled was stuck and wouldn't run and I was so tired I lay back on the seat against the handlebars for about 1/2 an hour to recover and the machine and I completely disappeared in the snow. I was probably 20 miles from any house in a complete white out with a stuck sled that wouldn't run and the snow was almost up to my waiste not counting the drifts).
The next day the sled ran fine (and the conditions were awesome - best powder conditions I can remember in 23 years of sledding; actually that might not be true - I can remember times over the years when there was too much snow to get my 1966 Olympic, 1972 Olympic or 1978 340 RV through). I think it was shortly after that that a mild bog started to appear (it always bogged off the line a little though).
Anyway, I was trying to figure out what caused the galling on the intake side and thought ice crystals might be hard enough to initiate galling of the pistons (keeping in mind how quickly the pistons are moving and it takes some time for snow/ice crystals to melt). The piston bores, rings, and upper piston regions are in great condition, just the intake pistons skirts damaged.
I was expecting to see perfect looking pistons with cracked skirts due to fatigue; not galled skirts. I'd estimate 0.015" of material is missing off the center piston skirt (I can fit a 0.020" pin gauge between the piston and cylinder in some areas of the piston, no matter where in the bore I measure it). The mag side was missing the skirt entirely, and the clutch side had only minor damage (comparatively). On the dreaded blizard day, when I had looked inside the airbox, the mag side had by far the most snow in it.
If it wasn't the snow, what else could cause that sort of damage?
Steve S.
  #6
Old 03-17-2001, 11:06 AM
portgrinder
you could have iced up your carbs so that jets patrially plugged which means a leaner sled?
  #7
Old 03-18-2001, 07:25 PM
what you probably incountered was the snow "washing" the oil off the pistons,exspecialy on the intake side. and because of this theres no lubrication left then you get the gauling. if the sled would have ran long enough you probably would have seized it. the skirt could have broke when the cold snow hit the side of the piston causing it to shrink a little,become a little more brittle, and then excesive piston slap,or maybe you have too many miles on it and there was piston slap anyways.anyways LARGE amounts of snow can cause what happened to you.hpoe you get it fixed soon!
motor head
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
