1985 polaris indy 400 bogging - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Snowmobiles and Sledding > Snowmobile Lounge
Old 01-19-2005, 06:18 PM
snowhawgpa
Default 1985 polaris indy 400 bogging
i recently bought a 85 indy 400 in need of tlc. i got it to run and it ran well at first but now its hard to start and when you do get it to start it wont rev up. sometimes if i get it past the bog it takes off like wild any help would be great
Old 01-22-2005, 08:33 PM
Novice
pipe539 is an unknown quantity at this point
Default Re: 1985 polaris indy 400 bogging
Sounds like you need to pull the carb or carbs and make sure the pilot and main jet are clean and open. Make sure the gas filter is clean, and flows good. Also replace the plugs it dosent take long to fowl out when the sledd is started and stopped alot befor the its warmed up. also there is a plug that drains the bottom of the case of oil and gass this can also cause a problem. to find them there are located under the exhaust manafold and there is one per Cylinder and there is a washer in the plug also don't loose it . Hope this helps
[img]images/graemlins/scs.gif[/img]
Old 01-23-2005, 10:32 AM
snowhawgpa
thank you for your reply. i will try these things and see if it helps
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
