GM 14 Bolt FF 6 Lug Conversion Kit 529.99 - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Supporting Vendors > Snevey's Offroad
Snevey's Offroad Snevey
Old 09-07-2013, 06:16 PM
Snevey's Avatar
Novice
Snevey is on a distinguished road
Default GM 14 Bolt FF 6 Lug Conversion Kit 529.99
There is only one right way to build a 6 lug 14 bolt with disc brakes. The wrong way would be to start with a stock 6 lug SF axle. Our kit converts the common 8 lug Full Floating axle to 6 lug and comes with forged and CNC machined hubs.
Our brackets are machined from 3/8″ hot rolled steel plate. Sharp edges are deburred before sand blasting and powdercoating satin black. The kit includes a set of brackets, Grade 8 mounting hardware and a pair of forged and CNC machined 6 lug hubs to fit the 14 bolt FF.
What else will you need? (2) Rotors (1975 -1988 GM 3/4 ton 44 truck front) (2) Calipers (1975 -1988 GM 3/4 ton 44 truck front) (1) Set of brake pads (1975 -1988 GM 3/4 ton 44 truck front) (2) Soft brake lines (braided stainless steel lines available) (2) Banjo bolts Brake fluid Common Tools
If you want to keep your cable e-brake simply substitute 78 El Dorado rear calipers instead of the GM front calipers. Our brackets will work with both calipers.
Axles: 14 Bolt 6 Lug
__________________
SNEVEY'S OFFROAD 530-255-4302 "Quality Parts That Dont Break The Bank"
Like us on FACEBOOK & check out our website at www.sneveysoffroad.com/
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
