Heavy Duty GM 14 Bolt Rear Disc Brake Conversion - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Supporting Vendors > Snevey's Offroad
Snevey's Offroad Snevey
Old 09-07-2013, 07:04 PM
Snevey's Avatar
Novice
Snevey is on a distinguished road
Default Heavy Duty GM 14 Bolt Rear Disc Brake Conversion
Disc brakes are self cleaning and bring a weight savings of 50+ lbs making this is a great upgrade for your rock crawler, mud bogger or pulling truck. These brackets are made to fit the mighty Chevy/GMC14 bolt FF rear axle 1973-1988 like a glove. Backed by a lifetime warranty against breakage and made in the USA with pride, this 14 bolt disc conversion is absolutely the best you can buy… period.
The brackets are machined from 3/8″ steel plate. Sharp edges are deburred before sand blasting and powdercoat. The kit includes a set of brackets with TIG welded steel spacers, Grade 8 mounting hardware and safety rings to keep your bolts from backing out. ONLY 129.99
What else will you need? • (2) Rotors (1975 -1988 GM 3/4 ton 4×4 truck front) • (2) Calipers (1975 -1988 GM 3/4 ton 4×4 truck front) • (1) Set of brake pads (1975 -1988 GM 3/4 ton 4×4 truck front) • (2) Soft brake lines (braided stainless steel lines available) • (2) Banjo bolts • Brake fluid • Common Tools
If you want to keep your cable e-brake simply substitute ’78 El Dorado rear calipers instead of the GM front calipers. Our brackets will work with both calipers.
__________________
SNEVEY'S OFFROAD 530-255-4302 "Quality Parts That Dont Break The Bank"
Like us on FACEBOOK & check out our website at www.sneveysoffroad.com/
Old 09-07-2013, 07:07 PM
Snevey's Avatar
Novice
Default Brake Rotor Armor Upgrade 79.99
Now you can add rotor armor to any of our rear disc brake conversions. This is a necessity when using wheel spacers which tend to leave the rotor exposed. ONLY 79.99
Our rotor protection upgrade is made of slot and tab construction, CNC formed and TIG welded. The rotor protection upgrade includes powdercoating.
How to order: from this page, simply add rotor armor upgrade to your shopping cart along with the rear disc brake conversion of your choice.
Excludes front disc conversions and the 14 bolt budget kit.
Axles: 14 Bolt GM Rear, Dana 60 Rear, Dana 60 Jeep J20
__________________
Quick reply to this message
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
