dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | RC-Electric For discussion of off-road, electric powered, radio controlled model vehicles. |
04-17-2001, 05:08 PM
| | Family Left Me | | Join Date: Aug 2000 Location: Bakersfield, CA
| | Which Motors for my zilla?
Just got my Clodzilla IV full race kit and super rooster. Need motors now. I was looking at the Trinity Chameleon Pro motors. Do I buy any motor for the front and just reverse the polarity for the reverse rotation or will this not work on all motors? Which motors do you recomend? I like speed.
Jason  |
04-18-2001, 01:46 PM
|  | Keyboard Implanted | | Join Date: Sep 1999 Location: Central Coast of California
| | Re: Which Motors for my zilla?
on a "modified" motor you can change the "timing" of the motor to change the rotation. this is done by rotating the endbell. your best bet is to get a reverse wound motor that way it was designed to run backward. Tom Klippenstein
life is short, drink good beer.[img]/wwwthreads_images/icons/wink.gif[/img]
04-19-2001, 09:02 AM
As far as motors, i would ask you this. do you want more speed or more torque? For speed, Speed Gems Saphires are a popular choice, the are 17 x 1 and have 0 timing. In order to reverse the rotation, pull the endbell and rotate it 180 degrees. For more torque, opt for the Magnetic Mayhems. they area 22 x 1 with 0 degrees timing. With the Magnetic Mayhems, they sell a motor that is reverse rotation. just buy one reverse and one regular and you'll be set to go. If you want a little more info on the Zilla, check out this website http://www.rcmt.net |
04-24-2001, 12:26 PM
I used the Speed Gem Saphire's in my USA-1 They are a blast. They do have lots of torgue to climb almost anything but the speed was deffently there. Turned it into just 2 wheel stering because of the speed. as Mongoose said it all depends on what you plan on doing with it.
LOCO |
04-28-2001, 01:07 PM
Mmmk, I received my new speed gems 17T motors from fed ex yesterday and installed them. I am running a Novak Super Rooster ESC. The acceleration is very jumpy and not smooth at all. And when i let go of the throttle (in neutral) the truck jerks back and forth like crazy. I did the setup on the ESC like 4 times. What could be causing this? I wired the 3 capacitors to each motor like it said and everything. This is my first time setting up an ESC and non stock motors. Help!!! I got this thing to full speed and couldn't believe the difference from before.
Jason
Big Willy Style
04-30-2001, 08:41 AM
sounds like a glitch in your radio system. Make sure your antenna is not touching any metal. Try moving your antenna to another spot on the truck. Are you running an aftermarket chassis? If those suggestions don't help, let us know and we'll try something else. |
04-30-2001, 08:59 PM
I have a ESP Zilla IV Full Race Chassis. I had the antennae rapped around the rear body mounts. I will move it and see what happens. Thanks for the info. I'll let you know.
Jason
Big Willy Style |
05-01-2001, 08:30 AM
I have heard of some people getting interference with the antenna like you have it. do you have the alumminum mounts or are they plastic? |
05-02-2001, 01:45 AM
They are the alluminum ESP grave digger body mounts. There is no place to mount an antennae tube.
Jason
Big Willy Style |
05-02-2001, 08:46 AM
If you have not tried this board yet, try it. There is a lot of great information on it and great people. They will be glad to help give you some advice. There is a section just about the clod, even an area moderated by Eric, the owner of ESP. I have been active on the board for about 2 years now. Great people over there. http://www.rmct.net | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 12:21 PM. |
