| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Ford Ranger, Bronco II, Explorer Discussion of all Ford mini and mid-sized 4x4 vehicles to include the Ranger pickup, Bronco II and Explorer SUV's. |
11-19-2005, 08:40 PM
| | | Front Axle Swap To Solid Axle? Hey everyone.
I was told that a solid axle is alot better for off-roading. I currently have the Twin I beam setup on my truck, and am wondering if it would be best to put a stright axle under it? I plan to put a lift on my truck also If anyone knows which lift kid would be best for a twin axle setup. Thanks
Mike
1991 Ford Ranger 4x4
2.9 L EFI |
01-03-2006, 02:39 PM
| | | Re: Front Axle Swap To Solid Axle? A solid axel is much better for many 4x4 applications. But if you just wanna go out and screw around in the woods the TTB does fine. People who do the solid axel swap will most commonly use either a early bronco dana 44 or a waggy 44. the waggy is a little wider so the tires will stick out. I have not seen any kits for solid axel swaps on ranger/ bronco 2/ explorers so that means that it will all have to be custom. |
01-16-2006, 10:02 AM
|  | Veteran | | | Join Date: May 2003 Location: Georgia
| | Re: Front Axle Swap To Solid Axle? There are two questions you need to ask yourself before a sold axle swap.
1. Do you have the time and money?
2. Do you have a reason to justify swapping the axles? Is the TTB giving you trouble? Are you always breaking parts becuase of hard wheeling? If not you probably dont need a SAS.
But, if you do, Jeff's Bronco Graveyard has a SAS kit that includes all brackets and hardware needed to do the swap. |
01-10-2007, 04:33 PM
| | | Re: Front Axle Swap To Solid Axle? If you are serious about solid axle conversions, check out this site... http://www.setstr8.com/
This may help you. |
03-28-2007, 05:03 PM
|  | Newbie | | | Join Date: Jul 2006 Location: San Diego
| | Leave Your TTB unless you are going to use your ranger as a trail rig only | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Need Gas Mileage & Power?- Free flowing performance exhaust can
Exhaust has for your gas or diesel truck. | Off-Road Videos - Check out over ten years of extreme 4x4
action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the
dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki,
Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and
model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 07:12 AM. |
