30ft Trailer - 17ft open trailer & 13ft LQ's
4 new tires matching
New brakes on all 4 wheels
2ea - 5200 lb torsion axles w/ 8 lug wheels & 1 spare.
Storage under vehicle.
LQ has new paneling throughout, new molding throughout, new carpet on gooseneck, new lights, and 130 yr old cypress wood and shelf. Microwave, toaster oven, sink, wet/bath area, 7 gal hot water tank. AC blows cold, but does not have heat strip. Real granite counter top and real slate flooring. Has black water tank and grey water tank. Has regular camper sewage hook-ups and whatnot.
For the people who what a short type trailer this will work for you !!! It is 17ft from hitch to front axle. Makes for easy getting into filling stations.
It has a 2100 lb tongue weight and over the axles is 5160 lbs. So you can load 5200 lbs of vehicle/equipment on the trailer.
The only thing this trailer needs is a paint job on the outside and fix the quartz lights on the outside and that is it !!
Call if you have questions. (337) 962-7172
$7500
$7500
