ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Racing and Competition > Mud Racing - Monster Trucks
Mud Racing - Monster Trucks Discussion of closed course mud racing and Monster Trucks, all aspects.
Old 03-14-2000, 04:01 AM
Default 35 spline 9\"
Seeing as my Toy is in the shop for a little while for susp and headers. I've got 28 spline axles on my early Bronco 9" with a lock-right. I'm looking at getting some 31 splined axles cut locally. Can a 35 spline be cut out of a full length 31. Also where would I look for 35 spline side gears for my Lock-right, if they work? I posted this on the Early Bronco forum to no responce. Would 35 spline axles be worth the effort, or should I just get some 31's seeing as the side gears would be more plentifull?
Thanks in advance PJL.
p.s. I'm about 4400 lbs soaking wet with 40"ish tires, and a 225 hp Ford 5.0, C-6, NP205
Old 03-14-2000, 01:28 PM
Default Re: 35 spline 9\"
Stay with the 31 splines. Not worth the extra money to go to 35. With all of my hauling and racing on a 9" rear, I've only broken an axle once. It broke right after the splines but luckily the axle was still supported by the diff. bearings. Seeing that I had a Detroit locker in it I was able to make it home OK. Racing - I was running a 460 cid and 38x16x15 S. Swampers with no problems.
Did it go together nice and easy? You did something wrong.Will have to do it again.[img]/wwwthreads_images/icons/crazy.gif[/img]
DaveC
Old 03-14-2000, 09:25 PM
Thanks, you've eased my mind, and probably cost.
PJL
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
