Re: Does anyone race pro arena?
I don't personally race pro arena- but I have several friends who are fairly competitive in the PACE motorsports series and and the Special Events Jamboree Tough Truck series. Four wheel drive is the only way to go- it's nearly impossible to do 180 degree turn and get going fast enough to clear the jumps and whoop de doos without it. The wheel base that seems to work best is kind of in between a full size truck and a jeep. Full size broncos and blazers seem to work well. As far as suspension- soft, soft, soft. at static the truck will have 4 inches of compression and like a foot of droop. That keeps the center of gravity low for cornering but allows enough suspension travel for adequate damping. also- slap as many long travel shocks on it as you can. And buy the special ones that allow instant droop and resistive compression. I don't know what the valving is that allows that. If the rules allow it- move the engine back to keep the weight centered between the axles and whatever axle you use- truss the hell out of it. I've seen guys use the "weakest" axles imaginable- but they live because the housings are trussed to the point where they cannot possibly flex. Run a fairly low profile tire, with aggressive tread- and keep it aired up pretty high. Let your suspension do the absorbing- let the tire do the gripping. You'll be grateful when it comes to cornering. I've seen guys try to run a stock lift kit with 38s or 44s and the tire nearly folds over during cornering and the suspension barely flexes at all- the tire is absorbing nearly all of it. Also, run anti sway bars bigger than you think is necessary. So many of the courses are becoming tighter and tighter because of the smaller venues and the races are won in the corners. I hope this info is helpful, Luke
87 Wrangler, 360, 39.5 Boggers, Dana 44s
