Re: TRANS SWAP
I have a couple ideas. My school of thought on conversions are either factory or aftermarket parts, then fabrication if the first two options will not work.
I'll start with the Turbo 350 kick down first. In the mid 70's Buick used a Rochester 2G carburetor with it's 231 engines. Most all of these mid 70's Buick cars also used the Turbo 350. It could be that a combination of mid 70's Buick 231 parts (carburetor, brackets, and kick down) could be adapted to your 71 Commando?
My first thought about the emergency brake cable was to get a new cable fabricated to a longer lenght. This may sound simple, but not everyone is located near a place to make cables. Many yacht / boat repair facilities can help. It might be possible that a similar year Wagoneer might have a cable that could work?
A day at the junk yard could generate several options also. |
