Steering damper?
As I was tightening the steering box on the 70 Jeepster, I noticed the damper looks like it might need to be replaced. I checked the 73 parts rig I have and found it not to have one at all, nor any indication that it ever had one. I do recall a thread to the effect that you could totally take the steering damper off. It is connected to the axle and to the steering rod (If that is what that long rod is that goes fully accross the front) with a shock type thingy in between. Would that be what you all were referring to?
Thanks
Ps,,Thanks to Mike for the advice on tightening the bolts on steering box. I took the bolts out, put in new ones and larger washers,,works great now.
PSS,,I thought I wouldn't like this new look but hey,,it is the Jeepster owners that have made this a wonderful chat area, so don't get too into the look,,just keep up the good chatter!
1970 Jeepster
1971 parts
1988 Harley Davidson
