ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
Old 09-18-2009, 12:53 PM
Journeyman
chains20 is an unknown quantity at this point
Default Question for a 350 in a jeepster.
Hey all. I have the motor and all between the frame rails and was wondering if anybody had found some headers that went outside of the frame rails. I know i can make it work with the factory ram horns but it seems that it would free up some space to move the exhaust out. Thanks for any help.
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
Old 09-18-2009, 01:31 PM
Newbie
daheepster is on a distinguished road
Default
You should be able to find some for a 350 conversion in a CJ. They should be close enough to make them work.
__________________
1970 Jeepster Commando
225 V6
Manual 3 Speed
Old 09-18-2009, 08:20 PM
Tim's Avatar
Tim Tim is offline
Tim is an unknown quantity at this point
Default
If you do go under the frame outboard, make sure you have a skid plate under the pipe and muffler that resides below the frame. Those that don't eventually wind up crushing the pipe which could have dire consequences. I used the ramhorns and stayed inside the frame on mine.
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
http://jonesys.com
Old 09-21-2009, 01:09 PM
Journeyman
Default
Thanks for the replys guys. Wel looks like i may go with cj6 fenderwell headers from advanced adapters. I hope they do not hang too low. I too was going to stay with the ramhorns but noticed that it takes up alot of room and did not want the y pipe hanging beloe the tranny. Thanks again guys.
__________________
71 commando
  #5
Old 09-21-2009, 04:21 PM
Tim's Avatar
Tim Tim is offline
Default
Mine hangs down just slightly below the trans, but is shielded by skid plate. The Flowmaster Y pipe is mounted vertically just inside the frame in line with the body mount.
__________________
Tim
http://jonesys.com
  #6
Old 09-23-2009, 12:53 PM
Journeyman
Default
Looks good. what did you end doing with the steering? I have worked in a hot rod shop and understand moving the steering but didnt like any of the angle or placement of the added ujoints.
Thanks for the info
__________________
71 commando
  #7
Old 09-23-2009, 05:31 PM
Tim's Avatar
Tim Tim is offline
Default
From the steering box, there's a slip shaft with u-joint connecting to solid double-d shaft that goes thru a carrier bearing mounted on the frame connecting to u-joint and the steering column. Can just barely make out the u-joint to column connection under the brake booster in the last pic.
__________________
Tim
http://jonesys.com
  #8
Old 09-24-2009, 12:26 PM
Journeyman
Default
Good info and very nice pics. Thank you for your help.
__________________
71 commando
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
