dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/ |
09-11-2009, 09:21 PM
| | Newbie | | Join Date: Sep 2009 Location: utah
| | steering problem
Can anyone tell me how the steering shaft is hooked into the column. Looks
like the only thing holding mine in is the rag joint. It's moved out far enough so the horn doesn't work anymore. Thanks for any input, Jim
09-14-2009, 12:11 PM
| | Journeyman | | Join Date: Nov 2002 Location: Spokane Valley,WA
Well mine is a 71 with power steering so im not sure if this will help but min has a u joint at the bottom of the column and the reg joint is closer to the power steering box. If you have manual steering somebody else will have to chime in.
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
09-15-2009, 11:42 AM
|  | Veteran | | Join Date: Sep 2002 Location: Ontario,Canada , Asheville, NC & points in between
Gotta figure you have Ross steering since that's the only one used a rag joint. On the bottom of the column tube there's a bushing that's held in place by two 5/16 head screws. It's not too easy to see when the column is installed but there are off set slots in the tube that allow adjustment of the inner steering shaft up and down. I'd be checking the bottom of the column for rust. Another thing that could happen is as the body bushings compress with age or the body supports rust, because the column is mounted solid to the body, the bushing will wear faster and push the shaft up through the column. Just a thought, hopefully not that but it wouldn't surprise me.
__________________
70 Jeepster Vert
73 Bullnose HT
73 Bullnose HC clone
72 Bullnose ???
71 Jeepster HC
71 Jeepster Hurst
02 Dodge 2500
Bunch of AMC Eagles
09-15-2009, 07:26 PM
| | right on - thanks Quote:
Originally Posted by Pack Rat Gotta figure you have Ross steering since that's the only one used a rag joint. On the bottom of the column tube there's a bushing that's held in place by two 5/16 head screws. It's not too easy to see when the column is installed but there are off set slots in the tube that allow adjustment of the inner steering shaft up and down. I'd be checking the bottom of the column for rust. Another thing that could happen is as the body bushings compress with age or the body supports rust, because the column is mounted solid to the body, the bushing will wear faster and push the shaft up through the column. Just a thought, hopefully not that but it wouldn't surprise me. | Wish you would have been a day earlier, would have saved me a bunch of work. I pulled everything out including the wiring for the turn signals and horn. The screws were loose enough so that it had backed the adjustment all the way back. Readjusted and tightened the screws and all is well. Thanks for the reply, really appreciate it. Jim
09-15-2009, 07:28 PM
| | Thank you Quote:
Originally Posted by chains20 Well mine is a 71 with power steering so im not sure if this will help but min has a u joint at the bottom of the column and the reg joint is closer to the power steering box. If you have manual steering somebody else will have to chime in. | Wish I had the power steering. Thanks for the reply. Jim
09-15-2009, 07:54 PM
At least it wasn't the worst case scenario  .
__________________
70 Jeepster Vert
73 Bullnose HT
72 Bullnose ???
71 Jeepster HC
71 Jeepster Hurst
02 Dodge 2500
Bunch of AMC Eagles
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 03:29 PM. |
