dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/ |
09-04-2009, 09:37 AM
| | Newbie | | Join Date: Aug 2009 Location: NM
| | 1967 Jeepster TH400 Transmission ID
Hello
I have a 67 Jeepster, Buick Engine 231 which I have rebuilt and replaced the Original engine , using the original adapter ring, and a TH400 transmission, with the balance of the Jeepster being pretty much stock, I have noticed that the transmission is starting to make some noise, so I am considering trying to find a second tranny to rebuild, but have been unable to locate the tranny detail information so that I might get on out of wrecking yard local. The Tag on the Tranny list the following information BJ-65-40706, SN 344, I have been unable to identify what GM transmission this is or what the numbers of the code indicates.
Is it a special built only for Jeepsters? or is it a off the shelf from a early model GM vehicle.
If you have any information about the about Transmission tag, that you could make available or tell me where I can go on the web to track down a the information.
Thanks TC
09-04-2009, 12:33 PM
|  | Keyboard Implanted | | Join Date: Sep 1999 Location: Vancouver, WA, near Portland, OR
It's an early 60's Buick/Olds/Cadillac, aka "round top" cased TH-400, not to be confused with the later, (mid to late 60's), model Buick/Olds/Pontiac, aka "twin ears" cased TH-400 that would fit your engine without the adapter ring. These "round tops" were designed for 4WD with shorter output shaft and no tail housing, so even though you could find one from an early GM car, it would have the wrong output to work with your transfer case. Jeep used these 4WD TH-400's from '66-'73 in Jeepsters and Commandos and from '66-'72 in Wagoneers and J trucks, should you desire a spare to rebuild.
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt http://jonesys.com |
09-05-2009, 01:21 PM
| | Addict | | Join Date: Nov 1999 Location: St. Louis, Mo.
| | Transmission
I have a couple of the original round tops. Send me an email if you are interested justjeepsters@aol.com
__________________
2007 Suburban
7 commandos
3 guitars
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 04:46 PM. |
