ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
  #11
Old 07-02-2009, 03:03 PM
Tim's Avatar
Tim Tim is offline
Tim is an unknown quantity at this point
Default
This what you're referring to Randy?
If so, they can be found here:
18271.12 - Omix-Ada - Rear Driver Side Spring Plate for Jeep : Tellico 4x4
and
18271.14 - Omix-Ada - Rear Passenger Side Spring Plate for Jeep : Tellico 4x4
And is this the shock you were referring to?
For 84-01 Jeep Cherokee XJ with 0" Lift
https://www.quadratec.com/products/16010_560.htm
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
http://jonesys.com
  #12
Old 07-05-2009, 12:06 PM
Randyzzz's Avatar
Randyzzz is an unknown quantity at this point
Default
Yeah, Tim, Those are the spring plates, they moved the shock body out at least 1/4". I had a set from my Scrambler laying around.
Those are the Edelbrock IAS shocks, those should have no clearance problems at the lower mount. They fit the Jeepster by just pressing the upper crossbar.
Non-Edelbrock style shocks should work too. I'm using Superlift Cherokee shocks, pressed out the upper pin and they bolt on. Just make sure to get the correct length.
__________________
Randy S.
It's not what you buy, It's what you build
82 Scrambler 5.3/4L60E/241OR/D44&HD20 4.56/lockers
90 Grand Waggy 350TBI/700R4
53 Ford Tudor
  #13
Old 07-05-2009, 03:04 PM
Tim's Avatar
Tim Tim is offline
Default
Quote:
There lies the key as if one searches for a Cherokee shock, the listing will be for either stock height or for say a 3" or more lift, but probably won't say what compressed and extended lengths are which are needed to determine if they will apply to an indivdual's Jeepster that may or may not have any lift to it. Pretty sure that all the Edelbrock shocks in a particular series, ie PERFORMER IAS as indicated in above post, will all have the same body width and only vary in length. Same should hold true with other manufacturers, ie Bilstein 5125 series.
__________________
Tim
http://jonesys.com
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
