dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/ |
06-14-2009, 11:26 PM
| | Stranger | | Join Date: Aug 2006 Location: utica ny
| | flywheel woahs... woes? wuws?
so i did the basterdization swap and have a 350 buick motor tucked carfully under where the hood would be on my commando...
so my question is, can i use my 225's manual shift flywheel on this motor? (i know it will bolt to it)
or is there a counter balancing issue to deal with? i really would like to keep it standard shift and i do understand the t14 wont last long behind such a monster as i have.
the motor is a 68 gs 10:1 comp 350(or so im told) if that helps you guys out...
thanks guys
06-15-2009, 06:25 AM
bueller? anyone?
06-15-2009, 09:55 AM
|  | Can't Get Enough | | Join Date: May 2002 Location: Winchester, VA
I believe you have to get it rebalanced for the 350, but don't quote me on that.
Chris
__________________
68 and 70 Jeepsters
"Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas Edison
06-15-2009, 02:23 PM
| | Addict | | Join Date: Jul 2001 Location: San Jose, Ca
I ran an odd fire flywheel behind an even fire 231 for many years.
I had to re-balance the flywheel to match the 231. I used my 231 flex plate for refrence when I took the fly wheel down to the machine shop for balancing.
The T-14 will not last long behind that engine if you drive like I do!
I would start looking for another tranny(T-18, 420 or 465) and t-case or go auto with a turbo 400.
I like My T-18 very much but sometimes I wish I was running an auto instead.
Good luck with the project.
Ken
__________________
69 Jeepster, 4.3,T-18,twin stick Dana 300,Waggy axles,High Steer,Detroit locker rear,ARB front, 8 pt rollcage, 36 inch tires,
06-15-2009, 10:01 PM
i have an automatic fly wheel off of another 350. could i use that as a template?
am i going to have to take the fly wheel from the odd fire to a shop with my motor to get it balanced?
06-16-2009, 09:18 AM
You won't need to take the engine in to get balanced.
Take the automatic flywheel/flex plate and the odd fire flywheel to the machine shop to balance the odd fire flywheel equal to the 350 flywheel/flex plate. You may have to call around to confirm that the shop can do the job.
I had one shop that was local to me that was able to do the work.
Ken
__________________
06-16-2009, 01:36 PM
| | Stranger | | Join Date: Feb 2009 Location: Ann Arbor, Michigan
You should not have a problem finding a flywheel for that engine though.
Otherwise, you would have to rebalance the oddfire flywheel.
you can look for a 231 evenfire flywheel, I belive they are the same for the V8 as well.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 12:54 AM. |
