ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
Old 10-06-2008, 11:01 AM
Zach Landrum
Default What's wrong with this?
Hey Guys - i recently got a 69ish jeepster, and was told by someone on another forum that this would be a problem, but i'm pretty new to all of this and was wondering why it is a problem? thanks! (spring over and single leaf)
edit: also - does anyone have a template or measurements of a bikini top for a jeepster commando - going to make my own. thanks agian-
Zach
Old 10-07-2008, 10:07 PM
Apprentice
HOWDY is an unknown quantity at this point
Default
With soa and single leaf the axle has more leverage on the spring and will turn it into a pretzel or bad s curve. Acceleration and deceleration will badly contort the spring. Results are bad wheel hop, less control, and possibility of busting drive shaft ujoints. Lifting soa on a mono leaf will make for a scary ride. Please for safety do not operate for long like this.
__________________
71 deluxe, 225, sm420, HEI, 60" D44s, SOA, lockers, 33x10.5s, york air, ....
Old 10-08-2008, 12:30 AM
Zach Landrum
Default
huh wow - thanks for telling me, i figured if no one would answer it wouldn't be to big of a problem, which of the 2 would you suggest i keep and use? i won't be doing anything to crazy in it - just normalish off-roading, camping and things of that nature. i really appreciate your input, alot.
Old 10-08-2008, 01:36 PM
AandMjeepster's Avatar
Aprentice
AandMjeepster is an unknown quantity at this point
Default
I agree with howdy, you need to get rid of the mono leaf as soon as possible. With it spring over axle you will get a lot of body roll in the corners and a lot of axle wrap. You do have several choices though: Find some stock multi leaf packs and keep it SOA, order some Alcan springs for SOA or SUA, or get some 4" lift SUA springs from Hell Creek suspension. Stock springs will work fine SOA, they are long enough to combat axle wrap.
You might want to consider welding some shock mounts to the bottom side of the axle tubes so you can get a little more travel. You do not get very much compression when the shock is mounted that high (unless you have A Lot of lift)
Also, I think your drive shaft was installed backward. I have never seen one with the slip joint at the axle, it is normally up by the t-case.
Good luck with your project!
__________________
1971 Jeepster: Rebuilt 225, HEI, d44 widetrack, d30 widetrack, sm420, d300 w/twinsticks, PS/PB, sitting on 35" super swampers
  #5
Old 10-15-2008, 03:48 PM
Zach Landrum
Default
So which do you think would be the best to keep? - i'll be using it for medium off roading and road usage. or do i really need to get another set up in the back?
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
