ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
  #11
Old 05-05-2008, 10:45 PM
Truckzilla is an unknown quantity at this point
Default
Quote:
Originally Posted by Tim View Post
You're funning me, right?
Now would one Jeepster owner do the to another Jeepster owner??
  #12
Old 05-15-2008, 01:03 AM
Tim's Avatar
Tim Tim is offline
Tim is an unknown quantity at this point
Default
Well I got to drive it on the street a bit today and came up with the following conclusions:
1) HT383E has poop aplenty!
2) The 1800-2100 stall torque converter was a mistake and will be replacing it with a 1300-1700 stall converter.
3) After going from 1 1/8" to 1 1/4" to 1 5/16" bore master cylinders, I believe we are real close to having the brake issues resolved. The 1 5/16" bore unit is the clear winner. It crosses to a '72-'73 GM 1 ton 4WD truck. The pedal now goes almost to the floor on first pump, but comes up some on second pump, (with previous master cylinders, it went all the way to the floor on first pump, but stopped at low speeds with rears only). The fronts are the problem with the huge caliper pistons. Tomorrow, hopefully, we'll get around to adding 2 psi residual pressure valves to front lines to keep some pressure on the pistons, to see if it reduces the pedal stroke some. If it helps, but isn't quite enough, 5 psi valves should do the trick.
4) Springs are probably perfect for off-road, but too soft for moderate to high speed, (freeway), driving. Will need to talk to Charles at Alcan about adding a leaf or re-doing the main leaf. Will need to weigh it before so we can get it dialed-in better. I'm thinking it's gonna be close to 6,000 lbs. with all the steel we added.
Anyway, here's a few pics I snapped today of the Flaming River tilt column, hood prop rod, underhood LED floodlight and TJ style hood latch.
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
http://jonesys.com
  #13
Old 05-15-2008, 01:16 AM
Trickpatrick's Avatar
Journeyman
Trickpatrick is on a distinguished road
Default
Nice I was woundering if those hood latchs would work.
__________________
Trickpatrick.
North Idaho USA.
Woody: '69 Commando Dauntless V6, SM420, D20, D44, D30.
Build thread:
http://www.jeepstercommandoclub.com/...pic.php?t=6775
A jeepster is alot like 3 different family's living in the same apartment.
  #14
Old 05-15-2008, 02:40 AM
Tim's Avatar
Tim Tim is offline
Default
Quote:
Thanks. They do indeed work, but require some mods to the fenders, (making a pocket), for the lower half of the latch to fit in properly.
__________________
Tim
http://jonesys.com
  #15
Old 05-15-2008, 03:01 AM
Tim's Avatar
Tim Tim is offline
Default
Some more showing:
1) Lower rocker skid installed.
2) Air tank.
3) Front driveline D-60 flange mount 1410 yoke for up to 38 degrees angle.
4) Front driveline Atlas flange mount 1410 yoke for up to 38 degrees angle.
__________________
Tim
http://jonesys.com
  #16
Old 05-15-2008, 03:17 AM
Tim's Avatar
Tim Tim is offline
Default
1) Rear driveline with 1350 cv at transfer case and 1410 u-joint at the D-70R.
2) The sun finally came out in the Pacific Northwet, so I had to take another glamour shot.
__________________
Tim
http://jonesys.com
  #17
Old 05-17-2008, 01:22 AM
Randyzzz's Avatar
Randyzzz is an unknown quantity at this point
Default
That's one sweet looking rig, Tim!
__________________
Randy S.
It's not what you buy, It's what you build
82 Scrambler 5.3/4L60E/241OR/D44&HD20 4.56/lockers
90 Grand Waggy 350TBI/700R4
53 Ford Tudor
  #18
Old 05-17-2008, 02:39 AM
Tim's Avatar
Tim Tim is offline
Default
Thanks Randy. Hope we can hook-up some time in the not so distant future.
__________________
Tim
http://jonesys.com
  #19
Old 05-17-2008, 02:17 PM
Journeyman
Default
Hmm I guess when I do tube fenders down the road I could mod those in looks good.
Mine always fold in and get caught when lowering the hood.
__________________
Trickpatrick.
North Idaho USA.
Build thread:
  #20
Old 05-18-2008, 01:45 PM
Newbie
Zeppe807 is on a distinguished road
Default
Some more showing:
2) Air tank.
Tim, are the tabs that are welded on the bottom of the steps/rock-rails locations for you high lift jack?
Joe
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
