OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 09-25-2007, 10:03 PM
Newbie
HOWDY is an unknown quantity at this point
Default Dana 44 disc brakes with caddy calipers???
Couple of weeks ago I was at the pick and pull and scored calipers and brackets from an eldorado for $28 total. These are the ones with the e-brake built in. At that price they had to come home with me even if i don't use them for a while. Like most of you I am not going to buy someone else's $200 custom brakets when I could make something myself on the cheap. Any good ideas out there on how to use them on my '71 with dana 44?
__________________
71 deluxe, 225, 3spd, HEI, Disk brake D30,SOA,lockers,33x10.5s
Old 09-30-2007, 05:46 PM
Joe67Conv's Avatar
Joe67Conv is an unknown quantity at this point
Default
I'm sort of going through the same process, though I opted not to use the Eldo calipers. If you look at the TSM web site on Dics conversion for the D44, you can get an idea of how they shape their caliper brackets. They also show two eldo calipers. One uses a thicker rotor, I think a 1.25 or a 1 1/8" the other uses a 1" rotor.
Small GM Rear Calipers
A flat steel caliper bracket may require spacers to align the caliper to the rotor. It depends on whether you can mount to outboard side of the axle flange or the inboard side and the rotor you use. You might be able to use either the thicker CJ7 rotor from 1977-78 (1 1/8") or the 1" 1980-86 CJ rotor. You could mock up a bracket with some 1/8" hardboard and test the configuration and alignment. The TSM "kit" uses their own rotors and caliper mounts. They're plenty proud of the parts so I''m doing mine using a frugal approach. Actual out of pocket costs were only for new brake lines. I got bonus parts when I bought a Dana 30 front w/ disc brakes for $100. The gears came out for the new front widetrack build-up and the brakes are going to the rear axle. One could say the rear disc conversion cost $0...or anywhere up to $100, depending on how I choose to split the "cost" between brakes and gear projects. I'm also putting in all new bearings, axle seals, a complete diff rebuild kit and the Warn internal spline hub conversion. In the end, the cost really isn't cheap at all.
The caliper mounts are GM 1/2 ton truck (1973+ ish), calipers are the '77-78 CJ rotors. Everything lines up great without having to reenginbeer anything. Assembly is in progress with parts still being coated/painted, etc. As for e-brakes, I'm going to use a push/pull mechanical hydraulic "line lock". No cable system. I may opt to install the line lock on the front lines too, as a backup. Less than $100 for 2 of them.
__________________
Joe
'67 Jeepster Convertible - Deluxe Edition
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
