ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 09-12-2007, 02:49 PM
Journeyman
celcius232 is an unknown quantity at this point
Default Dana 27 Front Axle Lube?
I am resealing the closed knuckle Dana 27 on the front of my '71. Should the knuckles be filled to the drain plug with the same lube as the differential? Does a new inner seal and these felt type seals from Crown really keep the stuff in? I think the old Jeep manual says SAE 80--is this correct? Thanks. Brian
Old 09-13-2007, 03:51 PM
Stranger
Chris G. is an unknown quantity at this point
Default
I believe the manual calls for the same gear oil as in the axle, but the old Willys guys swear by a combination of bearing grease and 90W oil called - "Knuckle Pudding". This pudding consistency combo supposedly gives enough movement in the knuckle to keep all the parts lubed but won't leak past the seals. I used this on an old Willys Wagon with old seals and it worked well.
There is a sort of "recipe" here:
Rick's Willys Truck Homepage
Good luck,
- Chris
__________________
68 Jeepster Commando V6/3 Spd, Trailforge Rollbar, BestTop SoftTop
Old 09-14-2007, 11:05 AM
mbr mbr is offline
Journeyman
mbr is an unknown quantity at this point
Default
Second that. I've also used it in my manual steering box for well over 10 years with never a leak.
__________________
Lazy n Proud
Old 09-14-2007, 12:40 PM
Journeyman
Default
It sound like the stuff I pulled out of the knuckles. Do you mix it 50/50? bg
  #5
Old 09-14-2007, 07:07 PM
mbr mbr is offline
Journeyman
Default
50/50 mix is my understanding. Cold weather makes the steering a little stiff at first, but it loosens up.
__________________
Lazy n Proud
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
