ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 08-30-2007, 12:28 AM
Stranger
rocjeepn is on a distinguished road
Default engine swap for 69 225 auto?
Will a 350 chevy bolt up to the 400 tranny? Or do I have to stick with buick motors.. and if I decide to rebuild the 225.. how much power could I get out of it? Thanks in advance...
Old 08-30-2007, 01:46 AM
Randyzzz's Avatar
Pooh-Bah
Randyzzz is an unknown quantity at this point
Default
You'd have to either get a Chev case TH400, or use an adapter plate. I personally wouldn't go with the adapter plate, since there's already one on there. Stacking 2 would be asking for trouble. The 225 can be built to make good power. I just got my 231 swap running, it feels pretty good. Adequate, but not impressive. (I'm comparing it to a healthy 350 in my Scrambler...it's downright scary!!!)
__________________
Randy S.
It's not what you buy, It's what you build
70 Jeepster 231/TH350/D300 WT30/44
82 CJ8 350/NV3550/241OR/D44&HD20/4.56
90 Grand Waggy
53 Ford Tudor
Old 08-30-2007, 10:03 AM
Truckzilla is an unknown quantity at this point
Default
Doesn't the Buick V8 have better low end torque?? Cooling seems to be an issue with any V8 upgrade. Plus a lot of work to wedge them into the engine compartment. 231 Turbo would bolt right in and I hear good things.
Old 08-30-2007, 06:51 PM
phantom_jeepster's Avatar
Journeyman
phantom_jeepster is an unknown quantity at this point
Default
My 231 needs to be rebuilt but still has the power I need on and off road(it did when I drove it last anyway) When I rebuild I'm going to Welcome To TA Performance for my parts.
I like the idea of putting a buick 350 in a jeepster but I hate cutting to get one to fit.
You could go with a built turbo Grand National 3.8. The power people are getting out of that V6 is amazing.
__________________
Justin
69 jeepster Dana 30/44 disc brakes, Dana 300 SM420 soon!
93 Dodge Ram Cummins 250 All Stock
04 Dodge Ram 1500 All Stock
  #5
Old 08-31-2007, 12:14 AM
Stranger
Default
a 3.8 motor will bolt up to the tranny with no adapter??
  #6
Old 08-31-2007, 10:02 AM
Journeyman
Default
It should bolt right up as long as its a RWD 3.8. I'm not sure if a FWD 3.8 will.
__________________
Justin
  #7
Old 08-31-2007, 12:47 PM
Randyzzz's Avatar
Pooh-Bah
Default
It'll bolt right up. Bellhousing bolt pattern is the same. Make sure to use the 231 flexplate, though.
__________________
Randy S.
90 Grand Waggy
53 Ford Tudor
  #8
Old 08-31-2007, 05:32 PM
Stranger
Default
My buddy has a 1972 Chevy 350 in his garage and I have another friend that has a buick 350 that I can have for free.. will either of these actually bolt to what I have? or would they need adapter plates as well?
  #9
Old 08-31-2007, 07:23 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Tim is an unknown quantity at this point
Default
Both Buick RWD 231/3.8L & 252/4.1L V-6's will bolt up in place of the 225 without additional adapters or different motor mounts. There will be small issues to resolve, like a larger capacity radiator, for one, but not a big ordeal to switch.
While the Buick 300, 340 & 350 V-8's will all bolt up without additional adapters or different motor mounts, there are significant challenges to making this work properly. Cutting sheet metal up front and mounting a much higher capacity raditor forward to accomodate the extra bank of cylinders are a couple of items. You will need to switch to an electric fan or cut the front frame cross-member out and move forward to clear an engine-driven fan. These are but a few items of many that arise from this conversion.
The Chevy small block requires an additional 1/4" thick adapter to work with your TH-400 as well as different motor mounts. You will also have the same cooling considerations to tackle as the Buick V-8's.
Several people that have done V-8 conversions in Jeepsters have had considerable trouble keeping their motors cool while wheeling, so be prepared to deal with that with any V-8.
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
  #10
Old 09-01-2007, 09:43 AM
Stranger
Default
So.. if I plan to use my commando for part time nice day commutes to work, running on smooth forest trails, and the occasional rock legde climb out in Sedona.. what engine would all of you recommend for this? LikeI stated before.. it has the original 225 V6 that runs.. but would be rebuilding it if kept that motor. And if this motor is the best all around choice.. how much horsepower could I get out of it? I really appreciate all the info fellow Jeepers. It really helps.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
