ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 05-07-2007, 05:57 PM
Journeyman
chains20 is an unknown quantity at this point
Lightbulb Full size axles?
Alright since im doing the V8 thing I have a set of 1974 axles that are already spring over and I was wondring if i can use these axles without to much modification. The axles were attached to a J4000 that ended up being scrapped.
Thank you fot all of the help.
Matt
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
Old 05-07-2007, 07:50 PM
chdorsey's Avatar
chdorsey is an unknown quantity at this point
Default
You'll have to outboard the front springs or narrow the axles. That will be the biggest mod.
Chris
__________________
68 and 70 Jeepsters
"Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas Edison
Old 05-07-2007, 09:15 PM
Aprentice
LCAC_Man is an unknown quantity at this point
Default
Quote:
Chris
Yep, you'll be outboarding the spring mounts/shackle hangars.
Steering will be your next biggest issue. I'd recommend going with a hi-steer system.
Driveshaft lengths will change and brakelines will have to be reworked but that's pretty straight forward stuff.
If you're planning to run stock springs and bigger tires you'll also need some type of anti-wrap bar/device for the rear axle to keep from destroying the springs.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
ARB-HP60/Detroit-14bolt, 37's and H1's
All I lack is finishing up!
Old 05-07-2007, 10:03 PM
Journeyman
BRIANster is an unknown quantity at this point
Default
I believe all 74-78 waggys and j trucks had stock flat top knuckles and were 30 spline d44's. If the front is setup for sua you will need to have a perch welded on the cast portion of the diff housing to go soa.
__________________
Brian
69 Jeepster
225 w/HEI,TH400
  #5
Old 05-08-2007, 11:06 AM
Journeyman
Default
How much would i have to narrow the front? i should probably narrow the rear as well then huh. are there axles that i should look for that may work better then FSJ axles?
Thank you
__________________
71 commando
  #6
Old 05-08-2007, 05:21 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Tim is an unknown quantity at this point
Default
If you're going to do a soa, it's best to use a front axle that's been designed from the factory for soa. This will allow for less problems with steering and tracking when completed. GM & Dodge trucks would be good choices. It is unfortunate though that the best choices will require shortening if you want to keep the stock Jeepster spring positioning.
As to best axles that don't require shortening, then Scout II comes to mind at appx 57" wms to wms. But they are set up for sua and front axles have zero degrees caster, (Jeeps like 4 to 6 degrees).
No real good candidates that don't require major work to make them work well, but there are plenty of home-grown solutions out there in rigs to get the mission accomplished. Just don't know how safe they are on the highway.
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
  #7
Old 05-08-2007, 05:29 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Default
Here's the method we used to shorten my axles:
http://forums.off-road.com/jeepster-...hortening.html (Axle shortening)
__________________
Tim
  #8
Old 05-08-2007, 06:37 PM
Journeyman
Default
How! great write up. i dont have the means of which to do something like that yet. Maybe i will just look at getting springs made and staying spring under. Well I will call around first to see how much it would be to have a shop shorten some axles first though.
Thank you for all of the great information
__________________
71 commando
  #9
Old 05-09-2007, 12:12 PM
Jeepster Jim is an unknown quantity at this point
Default axle
When I shortened my D-44 axle, I did not want to pay the heavy price of having custom axles made up so I had the diff. shortened up so that the long side used early Bronco and the short side waggie. True, my axles do not stick way out like many guys like, but it was a lot cheaper to build and if I break an axle, I can easily obtain one.
__________________
Happy Trails, Jeepster Jim
  #10
Old 05-09-2007, 03:17 PM
Journeyman
Default
That is great idea! do you know what the width is then? i am not too concerned with the axles needing to be wide but would like to have atleast d44's since I will have a V8 and (if I calculated right) 35's. Another thing i was wondering was if one was to switch to coils instead of using leaf springs could the need to shorten the axles be helped?
Thank you all
__________________
71 commando
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
