| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster |
05-17-2007, 08:28 AM
| | Aprentice | | | Join Date: Nov 2004 Location: Oceanside, CA
| | Quote:
Originally Posted by chains20 Trailer? It will be street driven.
I would like to be able to cover the tires with at the most the pocket cutout flares from bushwacker. Will i be able to do this with those widths?
Also does that mean I would have to outboard the the front springs as I would rather not have to do that. | Mine is going to be a mostly street driven rig also, but when I take it out to the trail it will be towed.
If you use wheels with lots of backspacing (like Hummer H2 wheels with
5.5"BS) your flares should be fine, or do like Tim did and get the larger bushwackers.
You really need to be willing to do the outboard if your upgrading axles and going with bigger meats, it will make the rig much more stable and isn't really that much work. The stock front spring hangars on a jeepster are not suited for bigger stuff and you'll end up cracking your frame.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
ARB-HP60/Detroit-14bolt, 37's and H1's
All I lack is finishing up!
05-17-2007, 11:11 AM
| | Journeyman | | | Join Date: Nov 2002 Location: spokane,WA
| | OK this is looking a little less complicated. So since i can cover the most of the tire with the flares will I have to shorten the front axle at all if i do the outboard springs? Are there kits that you use to outboard or is it different on every vehicle? Is that where people have been using wrangler springs and such?
Thank you very much for all of the patience.
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
05-17-2007, 12:12 PM
| | Quote:
Originally Posted by chains20 1) So since i can cover the most of the tire with the flares will I have to shorten the front axle at all if i do the outboard springs?
2) Are there kits that you use to outboard or is it different on every vehicle?
3) Is that where people have been using wrangler springs and such? | 1) No need to narrow the axle. This really helps in the long run if you need replacement shafts.
2) Yes there are kits(BTF makes some sweet ones for early CJs) but I wouldn't go that way, you can buy nice spring and shackle hangars from Foothill Offroad and then just make a gusseted platforms from angle and flat stock, it will keep your cost way down and allow you the most freedom in positioning them on the frame.
3) Yes, the spring hangars from Foothill are for 2.5" wide springs so YJ application springs work well.
Here's the shackle hangar, they also have the spring hangars. https://catalog.foothilloffroad.com/...b91a42b9290f1c
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
05-17-2007, 02:11 PM
| | Sweet! sounds good. Now how well will the Wrangler springs take the weight of the 350/465/205 combo? I know its not lite. are there better springs to use? any pictures of how the gussets should look for strength?
thank you
__________________
71 commando
05-17-2007, 04:11 PM
| | Quote:
Originally Posted by chains20 Sweet! sounds good. Now how well will the Wrangler springs take the weight of the 350/465/205 combo? I know its not lite. are there better springs to use? any pictures of how the gussets should look for strength?
thank you | You wouldn't want to use stock YJ springs(way to soft), I'm using Rubicon Express 1.5" YJ SOA springs, they come in either 5 leaf (RE1444) or 6 leaf (RE1445). I've got the 1445's mostly because I'm putting a 90lbs winch up front. They have reverse wrapped eyes to keep the hieght down and are very flexy.
Given that your running a much heavier drivetrain than I am I'd use the 6 leaf version also.
Lot's of other brands out there though.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
05-17-2007, 04:33 PM
|  | Carpal \'Tunnel | | | Join Date: Sep 1999 Location: Vancouver, WA, near Portland, OR
| | Quote:
Originally Posted by LCAC_Man or do like Tim did and get the larger bushwackers. |
I have the 7" Warn Trail Flares. Warn makes both 6" and 7" flares, while Bushwacker only makes a 6".
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/360 Rambleturd/Quadra-Trac/D-44F&R
05-17-2007, 05:34 PM
| | ahh ok good information to know. with that 1.5 inch lift spring how much lift did you yield total? sounds like they could get soft if i put a bumber and winch on later.
__________________
71 commando
05-17-2007, 08:17 PM
| | Quote:
Originally Posted by chains20 ahh ok good information to know. with that 1.5 inch lift spring how much lift did you yield total? sounds like they could get soft if i put a bumber and winch on later. | Hard to say how much lift I got, I changed so much on my rig that it's hard to get a apples to apples comparison(I stretched and widened my frame and increased the wheel base 11"), I'm also mid build so lots of things are changing.
We finished my neighbors rig 2 years ago, he has the 1444's on on the front in a CJ7/5.3L/4l60e/NP241 d60front and rear and 37's, we measured his before (with 32's)and after and got it at 8" of lift, he's real happy with the 1444's they haven't sagged at all. He's running a beefed up XJ pack in the rear.
Heavy bumper, winch, stinger, heavier drivetrain... probably a good call to get the extra leaf.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
05-21-2007, 10:29 AM
| | Sweet lookin rig (although it is a bullnose  -) ok so i pretty much know how i would like to do the suspension and axles with all of the help. is there anything special you have to do to the frame to keep it from cracking? are there any pictures of one should attach the gussets or even build them? Also what years of ramchargers should I be looking for? did they come on any pickups?
Thank you all again
__________________
71 commando
05-23-2008, 12:11 PM
| | ok. I understood all of this when the post was newer but i got laid off  and am just currently getting back to working on the jeep. Does anybody have full size axles that are not shortened on there jeepsters? anybody convert to coils yet?
Thanks all
__________________
71 commando
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 10:57 PM. |
