OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
  #11
Old 05-09-2007, 07:19 PM
Jeepster Jim is an unknown quantity at this point
Default
Quote:
Originally Posted by chains20 View Post
That is great idea! do you know what the width is then? i am not too concerned with the axles needing to be wide but would like to have atleast d44's since I will have a V8 and (if I calculated right) 35's. Another thing i was wondering was if one was to switch to coils instead of using leaf springs could the need to shorten the axles be helped?
Thank you all
I think my diff width is around 57.5"
I'm not sure on the coil spring stuff.
__________________
Happy Trails, Jeepster Jim
  #12
Old 05-09-2007, 10:09 PM
ACOfficer's Avatar
Journeyman
ACOfficer is an unknown quantity at this point
Default axle shortening
I just shortened a Dana 44 from a 75 Chevy blazer. I took 4 inches out of the long side and used a shaft from an 80's wagoneer. I did it in my garage and it was pretty easy. Read this article: Narrowing a front Chevy Dana 44 for a SOA Scout II
I pretty much followed the same method and it was relatively easy. I only outsourced the welding. Cost me $30. Taking the 4 inches out left me with a 63.5 WMS-WMS and you can use the stock spring location.
__________________
73 Commando
90 Wrangler
98 Dodge Ram 1500
2 German Shepherds
11 boas and pythons
  #13
Old 05-10-2007, 09:23 AM
Journeyman
chains20 is an unknown quantity at this point
Default
Good information! Thank you both. the 57.5" width is pretty close to stock right? I cant seem to find the paper i wrote the widths on.
Thank you for all of the help
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
  #14
Old 05-10-2007, 03:48 PM
Default
66'-70 is 50"
72'-73' is 51 1/2
'85 dana 30 wide axle 56 1/2"
__________________
  #15
Old 05-11-2007, 11:34 AM
Journeyman
Default
Wow not as close as i was guessing. that means i would have to do front and rear. Can any body give me an estimated cost for a project like this? Im thinking that th 57.5" will be the way i go. Also does anybody have agood resource to find out axle shaft lengths so maybe I could find some stock axle shafts for the back?
Thank you still
__________________
71 commando
  #16
Old 05-11-2007, 01:17 PM
Default diffs
Thank you still
If you have a stock Commando D-44 rear diff, that will work fine. You can go to a WIDE D-44 diff such as out of a late 80's cherroke, CJ-7????? Not postive on that. BUT make sure the rear diff is at least 1 1/2" narrower then the frt. this is for tracking purposes.
__________________
  #17
Old 05-11-2007, 06:22 PM
Aprentice
LCAC_Man is an unknown quantity at this point
Default
Quote:
Yeah, a widetrack CJ-7 axle would be a good choice and pretty easy to find.
The Scout rear axle would also be a good choice.
How big of a tire do you plan to run? Below 35" the rear 44 will be fine but if your looking to go bigger you may want to look at some larger stuff.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
ARB-HP60/Detroit-14bolt, 37's and H1's
All I lack is finishing up!
  #18
Old 05-12-2007, 09:16 AM
chdorsey's Avatar
chdorsey is an unknown quantity at this point
Default
This page has a lot of good info on widths of axles from various vehicles:
Best Junkyard Axle Swaps - Tech Articles - JP Magazine
I'd try to find a rear axle that you don't have to shorten. That will save you a LOT of money. I'd think widetrack CJ, Scout II Rear, or maybe even the Isuzu Dana 44 (has disk brakes already on some (maybe all, I'm not sure) of them. I have a narrowtrack Waggy front and Scout II rear in mine. Tires stick out some but are within the legal limits with flares.
Chris
__________________
68 and 70 Jeepsters
"Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas Edison
  #19
Old 05-13-2007, 10:24 PM
Aprentice
oldjeepguy is an unknown quantity at this point
Default
So Jim. What would an inch and a half narrower do for tracking?
__________________
73 commando
67 jeepster
  #20
Old 05-14-2007, 01:37 AM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Tim is an unknown quantity at this point
Default
Not sure what it'll do for tracking, but with a narrower rear end you will be able to turn sharper than if both axles are the same width. My front is 62" while my rear is 60".
__________________
Tim
'66 Jeepster Commando w/GM HT383E/4L60E/Atlas II/D-60F & D-70R
'70 Wagoneer w/Buick 350 V-8
'73 J4000 w/GM L31/700R4/NP-205/D-44F/GM 14 Bolt
Search this Thread:
Advanced Search
Need Gas Mileage & Power?-
Off-Road Videos -
ATV Reviews -
