| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster |
02-19-2007, 04:52 PM
| | Stranger | | | Join Date: Nov 2004 Location: Southern Illinois
| | Need Help With SOA on front axle.
This is my problem. I have a 71 Jeepster with
dana 27. I welded new axle spring perches just opposite of the factory ones for the SOA. With the perches on and axle installed the differtial seems to be pointed to far downward for the driveshaft to work right. It runs out of articulation, and the u-joint yokes touch when it still needs to pivot more. I know that a longer driveshaft will be needed for the SOA.
This Jeep will be for Highway use along with off-road. I can see if I was to turn the differtial up and point it towards the transfer case that it would cure the problem. By doing this I know this would mess up the castor/ camber, I have seen a " cut and turn" done but would like to do something else before doing that. I'm looking for the easiest way to solve this problem. |
02-19-2007, 09:57 PM
| | Newbie | | | Join Date: May 2003 Location: Lenexa KS
| | Re: Need Help With SOA on front axle. One thing that will really help is to convert to a 1 piece drive shaft. You will need 2 1310 yokes (10 spline) to replace tiny origionals and a used cj front drive shaft (I don't remember what length). Remove origional pencil sized shafts and carrier support from tcase. Save bolts, put thread locker on them and put them back in with a couple of extra washers for spacers to retain the case oil. Swap out yokes, measure for shaft, and find used or make new shaft. Cheap easy upgrade for strength and better angles. Almost forgot depending on your combo you may have to do some exhaust or crossbrace tweaking but I had no problems with it. Good luck!!!! |
02-20-2007, 12:24 AM
|  | Veteran | | | Join Date: Sep 1999 Location: Monument, CO
| | Re: Need Help With SOA on front axle. Did you just eyeball the perches? If you get the perches off just a couple degrees, by the time you get the axle on it will really show up. It sounds as though you need to remove the welds, put everything together and turn the axle to the proper angle, then spot-weld. My buddy did this very same thing. It’s extra work, but with everything together and weight on the vehicle it made a difference.
He was actually doing a few other things at the same time, but this seemed like a logical way to go. You could try degree shims?
Rotating the axle a little to help the angle won't hurt anything unless you plan on engaging the front at highway speeds. There's no vibrating if you keep it at 2 MPH. You still have to deal with shaft length/travel.
Anyone. Can you do a 1-piece axle and still keep the old shifter? Would the new shaft be too close to the carrier bearing on upward travel? I just went to the 1-piece/twin stick without ever thinking about that. If you are good at fabrication you could probably make a new mount for the shifter that won't interfere. If I remember correctly, the top half of the carrier bearing housing is the bottom cover for the shifter housing and the bottom half of the carrier bearing is the mount to the tranny. If you remove the carrier bearing setup, then you need to fab a bottom shifter cover to tranny mount. Does that sound right? |
02-20-2007, 09:44 AM
|  | Old Hand | | | Join Date: Aug 2002 Location: Chester County(SE), Pa.
| | Re: Need Help With SOA on front axle. Have converted to a one piece driveshaft with SOA and no interference problems. It is an automatic and we just removed the bottom half of the carrier bearing support, leaving the top part (which is also part of the shifter housing) in place.
Another option if there is interference or you do not have SOA, is to just cut a flat bottom plate replacement and drill 4 holes, easy enough. That way you can make another improvement by adding a grease zerk to the bottom cover. Then it is easy to add grease to the shifter ocassionally and keep it freed up. Someone did this to one of our Jeepsters and it seems like a good idea.
The brace from the shifter to the transmission pan is a seperate piece and can be reused with a replacement bottom plate. You will have to use washers or a spacer to make up for the thickness of the original bottom plate with the carrier bearing support (original is about 3/8" or so thick instead of the replacement sheet metal piece on ours). Again, this only applies to an auto transmission, the manuals did not use this brace.
Brad. |
02-21-2007, 08:32 PM
| | Re: Need Help With SOA on front axle. The perches were welded just opposite of the others, with tape measure to center distance on each end of perch then tacked in placed. So I do know the perches are right.
Wtih the axle bolted in place you can tell the angle would be the same above the springs but now below the springs for the SOA.
I don't have a carrier bearing for the trans case output shaft going to the front axle. The driveshaft is connected to the yoke coming from the trans case and then goes directly to the front axle with a slip yoke on the driveshaft.
So I need 1310 yokes plus driveshaft to make it work, is there anything else that anyone can think of with this conveersion. I just completed the disc brake conversion for the front axle. Thanks |
02-24-2007, 07:48 PM
| | Aprentice | | | Join Date: Nov 2004 Location: Oceanside, CA
| | I won't profess to have any knowledge of the Dana27 but I've done a few SOA's (44's and just finished a 60), and many required correcting the pinion angle to get a decent lower u-joint angle/clearance.
A possible quick fix would be to install some caster shims under the springs to raise the pinion, but that's only if you've got some caster to give, you'll need to keep at least 2 degrees (tipped back toward the rear of the vehicle) to maintain any type of return to center on the steering.
Outside of that cutting and turning the Inner-C's to allow you to set the pinion anywhere you want it is the way to go.
__________________
Len Barron
72 Commando
5.3Chev/4L65e/NP241
ARB-HP60/Detroit-14bolt, 37's and H1's
All I lack is finishing up!
02-25-2007, 07:10 AM
| | Stranger | | | Join Date: Feb 2006 Location: south carolina
| | Based on what you are describing you may already have a one-piece drive shaft conversion which probably already has 1310 yokes. You can take measurements of the yoke diameter and width or just compare it to the rear. If the yokes and u joints are the same size as the rear then they are 1310s, but if they are noticeably smaller then they are the original size. |
02-25-2007, 07:26 AM
| | Have not done the one-piece and 1310 conversion on a D27, so I am not sure how hard it is to find or if the yoke even exists to do this on the D27.
But I can tell you that it works for us on a Dana 30 and there is no interference. Stock height front springs, SOA, one-piece drive shaft. When it was installed, I had to change the output yoke on the transfer case to match the driveshaft and the D30. Like you describe, our SOA perches are welded parallel to the stock ones.
Brad.
__________________
68 Jeepster being restored
71 Jeepster w/snowplow, SOA - Ole Yeller
68 Jeepster Half-cab
69 Jeepster, future half-cab?
02-26-2007, 08:31 PM
| | Ok. Rechecked the the perches everything seems correct. I pulled the output shaft yoke off the trasfer case and it has ten splines for the different yoke " 1310". I haven't pulled the yoke off the Dana 27 yet but if the yokes are bigger, with some more side to side movement I believe it might work.
If someone knows about the yoke interchange on the Dana 27 let me know. Oh does anyone have any used 1310 yokes you would be interested in selling let my know also.
Thanks |
02-28-2007, 10:51 PM
|  | Newbie | | | Join Date: Feb 2005 Location: Central Florida
| | if i can find (2) 10-spline cv style front yokes from 76-79 q-trac transfer cases, i will ship you mine for free
__________________
72 Commando--soa lift--2" add-a-leafs-- on 33's- swamper trxus m/ts-- lincoln locker in rear--lockrite front
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:36 AM. |
