ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 02-14-2007, 05:46 PM
Jeepster Jim is an unknown quantity at this point
Default tie rod to pitman arm clearance
My Jeepster has a severe problem with clearance between the tie rod and pitman arm and I'm wondering if any of you have had the same problem and if so, how did you correct it.
Here's what I have:
Dana 44 waggie frt. dif cut down to 57"
waggie pitman arm---6 3/4"
stock Jeepster P/S mount set up.
I found a shorter pitman arm...5 1/2" but it is NOT short enough for good clearance. Going to a shorter pitman arm will ruin my turning radius so I'm looking for a better way out. Yes I may need to move the Steering box foward or?
Old 02-15-2007, 01:48 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Tim is an unknown quantity at this point
Default Re: tie rod to pitman arm clearance
Jim:
Since I am visually impaired, (can't visualize in my mind from verbal description), pictures are worth a thousand words. Specifically, the box position and the interference problems.
Old 02-15-2007, 02:12 PM
Budd's Avatar
Budd is an unknown quantity at this point
Jim went to a high steer set up and is using Skye Manufacturing arms. Since he is using TRE's and the arm has machined in conical - he can't easily just move the Tie Rod to below the arms. Just to clear it up some.
Post up a pic Jim! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 02-15-2007, 03:46 PM
chdorsey's Avatar
chdorsey is an unknown quantity at this point
Jim,
I've got a nearly identical setup and just barely interfere. From what I have heard, a pitman arm from an Astrovan is just short enough to give you the needed clearance without compromising too much on the turning radius. Does yours look something like this?:
Chris
  #5
Old 02-15-2007, 10:04 PM
[ QUOTE ]
Jim,
Yes it did, however, I had to lower the tie rod and draglink to the stock postions because the tie rod would hit the frame. My frt. diff. is still sprung under.
By putting the tie rod in the stock steering location, the waggie pitman arm hits the tie rod. NOT GOOD.
I have been reading up on putting the tie rod behind the frt. diff but I'm not sure how well that works out for clearance and such.
Chris
  #6
Old 02-15-2007, 10:13 PM
chdorsey's Avatar
Do you have a custom steering linkage or are you running the stock Waggy setup? I guess what I am trying to get at is whether the drag link connects to the tie rod or directly to the knuckle. If they were separate, then you could still use your high steer for the drag link and put the tie rod down on the stock location to keep things from interfering.
Chris
  #7
Old 02-15-2007, 10:54 PM
I am in the CPU
RRich is an unknown quantity at this point
Why not, like a TJ, have the drag link connect directly to the tie rod? Check out the Currie or Poison Spyder systems. Lengths may be different, but they can make one the proper length.
  #8
Old 02-16-2007, 06:42 AM
chdorsey's Avatar
If I read what his problem is correctly, then there is interference between the tie rod and pitman arm. I was just asking if moving the tie rod to the stock location and keeping the drag link connected to the high steer would take care of the problem, not criticizing that setup.
Chris
  #9
Old 02-16-2007, 01:29 PM
[ QUOTE ]
Rich:
That's what I have now....basicly just like a stock waggie set up.
  #10
Old 02-16-2007, 01:35 PM
[ QUOTE ]
Chris
Chris:
When using the high steer set up, the tie rod will smack the steering shaft or frame. I moved the tie rod down to the stock postion and discovered that the pitman arm is to long. If I left the drag link on the high steer set up, the pitman arm would still hit.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
