ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
Old 11-13-2006, 10:51 PM
Kolapi
Default Clutch Problems
Hello,
I have a 1969 Jeepster Commando. I'm having a problem with the clutch. The clutch used to be real hard to push. A couple of years ago, the cable broke thru the floor, I broke a cable and bent fork. Then I found a website that said there was a cure for this problem. I bought the parts that this guy used and my clutch worked great for about a year.
Last week, the clutch cable just snapped. I bought a new one and the clutch is very hard to push. It worked once to test it out, then it broke the hanger on the back of the pedal. Any ideas?? Everything looks right. The fork looks like it's in place. Real hard to push again. Cable works smooth. Could the pressure plate be bad?
Would switching to an automatic tranny be a better idea? How hard would that be to do? I don't offroad with it. It's just an in-town cruiser that pulls my (light)sailboat.
Any info would be appreciated. I live in Iowa and have only seen 2 other Jeepsters around here in 10 years! I haven't found anyone who works on them. I do my own work anyway.
Eric
Old 11-14-2006, 10:01 AM
Mr. Fast Bucks's Avatar
Mr. Fast Bucks is an unknown quantity at this point
Default Re: Clutch Problems
Welcome,
Unless you broke something in your clutch, consider this:
hydraulic clutch setup
Once again, this won't fix a broken clutch, but it is one alternative to the cable....
Old 11-14-2006, 07:48 PM
RRich is an unknown quantity at this point
Do a search here for "hard clutch pedal cure" - it'll tell you part numbers, and how to make sure it's properly set up. Do it right and it's so easy you can use 2 fingers.
The cable - aftermarket cables are trash. Take one to a place that specializes in cables as a sample - phone book, "cables." They'll make you one much heavier and easier than stock. And it's cheaper than the aftermarket Chinese junk anyway.
Make sure the cable housing is lashed down so it doesn't move around like a snake = wasted motion.
It takes the proper TO bearing - the long one - the reason it got hard after awhile was you used the short one. It works till it wears slightly.
Old 10-29-2009, 08:25 AM
Novice
Bostonjeepster is an unknown quantity at this point
Default
Quote:
Originally Posted by Mr. Fast Bucks View Post
Welcome,
Hello,
The hydraulic link did not work any chance you can post it again?
Thanks,
Lanette
  #5
Old 10-29-2009, 11:40 AM
Newbie
38ford is on a distinguished road
Default
I followed the procedure written up by RRich on 8/13/00 several years ago. Worked like a charm. Thanks again RRich
  #6
Old 11-14-2009, 07:08 PM
big_bad_jeepster's Avatar
Journeyman
big_bad_jeepster is an unknown quantity at this point
Default
I would suggest switching it over to a hydraulic clutch setup as well. You can buy the parts from wilwood for less then $200. Drill a few holes and fab up a bracket, done.
Wilwood Disc Brakes 260-1333 - Wilwood Slave Cylinders - Overview - SummitRacing.com
Wilwood Disc Brakes 260-6766 - Wilwood Aluminum Master Cylinders - Overview - SummitRacing.com
__________________
Mike McMenomey
70 jeepster, fi 388 stroker, sm420, atlas 5, dana 60/14 bolt, 42's, linked with coilovers
www.rockzombies4x4.com
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
