For those of you with Saginaw steering and contemplating new springs to lift the vehicle, here are some tidbits I discovered in my attempt to correct the steering linkage. Not sure if Saginaw boxes from non-Jeep applications have the same shaft size and splines, so this may only work if your Saginaw box came from a Jeep, if your rig is pre-'71.
After installing the 4" lift springs on Punkin, it was evident we needed a dropped pitman arm to keep the drag link parallel to the tie rod.
Since it was a 4" lift, it seemed plausible that a dropped pitman arm for a CJ with a 4" lift would work on a Jeepster or Commando.
There are a few different companies that market these items, but I will discuss the ones from Skyjacker, since they seem to have the most options available for CJ's and those are the ones I jumped through hoops with to come up with a winner.
For a 4" dropped pitman arm, there are 4 possible choices:
1) - JA650 for 3-4" Suspension Lift on Jeep CJ 1972-75 with Manual Steering
2) - JA550 for 3-4" Suspension Lift on Jeep CJ 1972-75 with Power Steering
3) - JA150 for 3.5-4" Suspension Lift on Jeep CJ 1976-86 with Manual Steering
4) - JA250 for 3.5-4" Suspension Lift on Jeep CJ 1976-86 with Power Steering
Since Punkin has power steering, I decided to get both the JA550 & JA250 to compare and return the one that didn't work.
Both arms fit on the shaft of the steering box and appeared to look identical. Only thing that appeared different upon closer scrutiny was the size of the hole for the drag link to connect to. But both arms had too much drop causing the drag link to be below the tie rod, so on to plan B.
For a 2" dropped pitman arm, there are 2 choices:
1) - JA652 for 2" Suspension Lift on Jeep CJ 1972-75 with Manual Steering
2) - JA552 for 2" Suspension Lift on Jeep CJ 1972-75 with Power Steering
So the logical choice was to get the JA552. After returning the other two arms for this one, it was found to not fit on the shaft. By this time it was too late to contact Skyjacker in LA, so next day a call was made inquiring what the heck? It was decided that the box that this arm came in must have been mis-labeled JA552, when it should have been labeled JA652 for manual steering. I learned that the manual box shaft is slightly smaller than the power box shaft and that it's possible that the part you have may not the one it's supposed to be.
After checking with the local parts warehouse, we find out that we got their only JA552, (which is in reality a JA652) and another one wouldn't arrive until next week. Oh rat farts!
We checked with the other warehouse in the area and apparently the Jeep Gods were pulling for us, as this one did have a JA552 in stock. This box did have the correct arm in it and provided the necessary drop to put the drag link parallel to the tie rod.
Although there are other companies selling arms for CJ's, Skyjacker was the only one I found to offer a 2" model after an extensive Google search. All the other arms I found were either no drop or 4" drop. If there are any other options available, please feel free to post to this thread.
Here's a link that shows lots of different pitman arms available for Jeeps:
http://www.tellico4x4.com/index.php/cPath/459_438
Although this is getting a bit long, I thought I'd include some pics of how it turned out.
Here's the 2" arm in the vise and the no-drop arm next to it.
Since the front axle for Punkin is a D-44, the hole for the drag link needs to be reamed a bit.
Here it is installed, front view.
Side view.
