ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 06-17-2006, 11:47 PM
Newbie
Commando71 is an unknown quantity at this point
Default Bushwacker fender flare???
I was looking at the busher wacker fender flare -- I've seen iton several pictures on commandos on this site -- which fender flare is it?? -- I see tha Mike used Bushwacker Pocket-style fender flares. These are for a YJ Wrangler -- is this a special order -- what year -- where can I find these flares?????
Old 06-19-2006, 10:40 AM
MontanaJeep is an unknown quantity at this point
Default Re: Bushwacker fender flare???
I used TJ front and rear. I know that TJ style for the rear is best (taller and wider) and YJ or CJ front style flares are better to fit the lines of our Jeepster's. I used TJ front flares but I had to cut them to fit the front (TJ's mount to a flat surface where as Jeepsters have a moulded and rounded fender). I'll try and post some pics.
Old 06-19-2006, 04:09 PM
jeepsternut's Avatar
Aprentice
jeepsternut is an unknown quantity at this point
MontanaJeep,
I would appreciate some posted pics. I am getting ready to paint and install new flares this summer.
Thanks.
Jeepsternut Duane
Old 06-19-2006, 10:24 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
Tim is an unknown quantity at this point
I bought a set of 7" Warn TJ flares for the Beater. They are also available in 6" width. They are made of a polyurethane material and are a bit more pliable than thermoplastic. Not sure how they compare price-wise to the Bushwackers.
http://www.warn.com/truck/flares/trail_flares.shtml
If you want to save a bunch and don't mind thermoplastic, Omix-Ada sells 7" TJ flares for quite a bit less. Another advantage, besides price, is you can order just one later on, should it need to be replaced. I don't know if the other companies sell individually.
http://www.omix-ada.com/Catalog/p53new.htm
  #5
Old 06-19-2006, 11:02 PM
Tim's Avatar
Tim Tim is offline
Carpal \'Tunnel
If you have a '71 Jeepster, CJ-8 Scrambler flares will work very well, since the front fender has the running light built-in. Omix-Ada has a stock width set of Scrambler flares and Xenon has a 5" front/6.5" rear set.
Here's a site with some pics of a Scrambler with both stock and wide Xenon flares:
http://www.off-road.com/jeep/reviews/xenoncj8.html
  #6
Old 06-20-2006, 11:54 AM
I'll see if I can find some time tonight to do that for the front flares. There is a good write up from last week on the TJ rear flare install, it looks basically the same as the way I installed mine.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
