Jeepster-American Jeepster ClubThis board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
rear sag ? spring shackles ?? recurve leaf springs
Greetings brothers of the rust.. my ride be draggin a bit in the rear.. well not draggin but the fender cutout is BELOW the tire by bout 1/2".. shocks are good.. springs are fine for me.. I don't off road and would like to keep the softer ride.. quick corners do exibit a bit of body roll in the rear.. front seems fine.. ? can I .. should I consider adding links to lift the butt up from the spring shackle points?? How much can I go wihtout adverse effects?? can I do 4-6 inches?
Thanks in advance. and a safe Memorial day to all
Bob.
71 stock
Re: rear sag ? spring shackles ?? recurve leaf springs
Whats bad about the shackel lift??? I have them on both of my Commandos,had it on my 48CJ2A,91 Wrangler and on my M416.Never had any issues.Ran the Rubicon multiple times,Dusy/Ershum and many more.I think 4-6 inches is nuts,but 1- 1 1/2 is fine.
1 1/2" lift shackels for a Wrangler will work in the rear.And 1 1/2 XJ (Cherokee) for the front.Thats if you have 2" springs in the front and 2 1/2 in the rear.
GREAT INFO !!! Thanks all for your time, patience and expertise.. much appreciated.....
I think I will look at the 1 to 1 1/2" shackles (existing ones are 3".. Is that stock?) if that does not do the trick I will look at add a leaf or have the existing springs recurved..
I do have some body sag due to rust issues in the rear bed area.. but cant imagine that it would make up the 3-4 inch diff in front and rear clearance that I think I am seeing.. I certainly will get that squared away first prior to screwing around with lifts.. thanks and have a safe holiday... and if your a fellow vet, remember our brothers
Actually, with the Jeepter rear springs, your lift would only be about 1/3 the difference in shackle length, because of the fact that the axle is not in the center of the spring. In order to get about 1" of lift, you would have to use shackles 3" longer than stock. This is probably unsafe, and they would really drag on stuff off-road.
