Dauntless V6 Heat Control Value - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Jeep > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/
Old 12-15-2005, 07:23 PM
Stranger
katn is an unknown quantity at this point
Default Dauntless V6 Heat Control Value
Just replaced the exhaust system from the manifolds to tail pipes. Yes pipes. I went with a dual system, with pipes out the side instead of the rear. I think it's sweet.
While we did the install, it was found that the heat control value was stuck in the closed position. So it was just cut out. No wonder the engine ran HOT!
So the questions of the day is: Should I find a replacement, and where do I find it? Or do I go my merry way without it, but spend some more time warming up the beast before heading out on the road?
Old 12-16-2005, 12:09 AM
chdorsey's Avatar
chdorsey is an unknown quantity at this point
Default Re: Dauntless V6 Heat Control Value
When you say heat control valve, do you mean the piece that bolts to the pipes at the flange at the manifold? If so, I believe that is actually the control for the automatic choke for the carb.
Chris
Old 12-16-2005, 12:23 AM
RRich is an unknown quantity at this point
Heat riser - closed it directs the exhaust on that side to go up through the intake manifold to the other side, thus heating the carb.
It'll be harder to warm up now. Just let it warm up a little longer.
But you'll notice performamnce and mileage are improved by a bunch!
Old 12-16-2005, 04:13 PM
Tyrone Corn's Avatar
Tyrone Corn is an unknown quantity at this point
When I installed headers a few years ago, I discovered that my valve was frozen shut also. Made me wonder how it ran as well as it did. At any rate, it was eliminated with no ill effects.
  #5
Old 12-16-2005, 04:31 PM
badbrad's Avatar
badbrad is an unknown quantity at this point
RRich,
Wasn't there also a post about plugging up the crossover passages you described? Of course that requires the engine to be apart.
Brad.
  #6
Old 12-17-2005, 02:46 AM
Plugging the crossover would make it act even colder, even in moderate weather. Plus, it'd be a pain.
But you might remember a problem associated with it. Unlike newer engines, the 225 used the old style of carb heating. The crossover came up, right out of the manifold to the bottom of the carb, passed through a passage underneath the carb, then back down to the other side. That often burned the carb base and/or gasket, allowing exhaust gasses back into the intake == instant EGR, and too much.
The cure for that was just plug off the 2 holes under the carb.
But that still allowed hot exhaust gasses to heat the intake manifold some.
Remember, the carb is evaporating gasoline - gas has a low dew point. The evaporation/atomizing process removes heat - the carb can ice up even on hot days from the evaporation.
That's why it needs a little heat.
  #7
Old 12-18-2005, 10:14 AM
chdorsey's Avatar
Okay, I am probably going to get the exhaust bent up on mine pretty soon. Should I keep that valve in there or toss it? If I toss it, is there anything I need to plug up or do as a result? Thanks,
Chris
  #8
Old 12-18-2005, 10:32 AM
As long as it's still working I'd keep it.
It has to move freely, and the bi-metal spring has to still be OK.
When it's cold the spring closes the flap, redirecting some of the exhaust. If exhaust pressure increases much, then the force of the exhaust against the spring and counterweight opens it so it's not restrictive. When the spring gets warm, it stops trying to close it.
You can bench test it - at room temp and at the normal angle it should be closed. Play a propane torch or heat gun on the spring a moment, it should open up. DON'T OVERHEAT THE SPRING! The torch can easily ruin it.
Removing it presents a little problem - the top is a flange that bolts to the manifold, yet the bottom side the pipe attaches with a flared type connection. If you are building a new exhaust it's not a problem, but just removing it from a stock system you need to convert the connection.
Mine froze up in the partlialy closed position, too far gone to save it. I cut out what was left of the butterfly and removed the remainder of the shaft. That left 2 small holes where the shaft had been to weld closed. Easy.
If you are in a very cold area, you might want to consider keeping it.
By the way - muffler shops have brass nuts - they won't rust to the steel studs. Be careful the way you ask for them though.
  #9
Old 12-18-2005, 12:19 PM
chdorsey's Avatar
[ QUOTE ]
LOL. I will keep that in mind. I already have the system apart and the valve seems to be flexing pretty freely. I'll hit it very briefly with a torch and see if it responds. Thanks for the help.
Chris
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
