dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/ |
09-19-2005, 08:46 PM
|  | Journeyman | | Join Date: Sep 2005 Location: South Carolina
| | Auto Trans Should it stay or should it Go
New Guy Hear.
I have a stock 68 commando 225 v6 and the turbo automatic. The motor is being rebuilt and i was going to do the same with the trans, BUT I want dana 44 front and rear with a lift and 33's should i keep the automatic or upgrade to another automatic? Any info would greatly help.
P.S. I would like to keep it automatic Or should i just get a stick????
09-19-2005, 08:57 PM
|  | Enthusiast | | Join Date: Jan 2001 Location: Santa Clarita, Ca.
| | Re: Auto Trans Should it stay or should it Go
1. Welcome!
2. Some may ask for you to fill out profile a little more, (make sure your not a spy or sumthin'?)
3. It all depends on your plans for the Jeepster, and whether you mind shifting or not. A stick can give you better crawl and freeway ratios, but wheelin with an auto can be nice.
I had my th400 rebuilt with a 3.15:1 1st gear and have been very happy with it, but i wish it had some more legs on the freeway. it's all a trade-off.
Anyway, there have been plenty of discussions on here in the past about this, so the search function is your friend, but ultimately you have to decide for yourself.
I'd keep the auto. [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
09-19-2005, 09:04 PM
|  | Addict | | Join Date: Dec 2000 Location: Clovis Ca.
The terbo 400 is probably the best trans you can get for your money. "Just what you have". But unless you get a lower transfer gear or put lower gears in the rear ends you will not have low enough low range for rough off road stuff. 456 would be good in the rear ends.3 or 4 to one in the transfer case.$$$ it goes on and on. I have over $4000 from the motor back to the ground. and did most of the work.
09-19-2005, 09:06 PM
|  | Keyboard Implanted | | Join Date: Jan 2000 Location: Charlotte, NC
Welcome numbersjeep,
I've got a set of Scout 44's for ya if you're interested and am close to you.
Keep it simple and keep the A/T.
09-20-2005, 08:24 AM
| | Addict | | Join Date: Feb 2005 Location: Kzoo, MI
That tranny is as tough as they come for stock units. If it works good, keep it. If you change, then your looking at adapters, or finding different setups to make the change work.
09-20-2005, 08:30 AM
WOW!
Thanks for the replies, man this place has just become my new home. I am a little new at the off road subject so if i ask a dumb question i appoligize. I was wondering if i keep my A/T should i upgrade the transfer case? And if so, any suggestions so i can start looking or atleast get an idea on $$
09-20-2005, 08:34 AM
Ha. I like that (numbers jeep)
Yes i would be interested in those axels! [img]/ubbthreads/images/graemlins/yourock.gif[/img] I want to do a spring over lift with disk's at all 4 corners. Do you think the 44 would be a good set up??
09-20-2005, 09:39 AM
If you have the D20 t/c its a good one for this application, 44's are great if you got them too.
09-20-2005, 11:12 AM
DUMB ?
How do i know if it is a d20 and where should i look??
Sorry but i am new at this so try not to laugh at me, cause i am laughing enough at myself. BUT honstly this is Great THANKS everyone!
09-20-2005, 12:10 PM
|  | I Might Just Know What I'm Talking About | | Join Date: May 2002 Location: Selma,CA in the middle of the vineyards, Central California
You should have a Dana 20 T/C now if stock.
Bolt pattern between Tranny & T/C is often referred to as a "Texas" bolt pattern (shaped like Texas).
Dana 300's will be a round bolt pattern.
Dana 18 have offset drivelines: front & rear drive. off-set to line up with an offset front & rear axles to the passenger side(older jeeps).
Those Scout axles are a great improvement but you will not be able to just bolt them up. Do some research. Scout fronts have zero camber and you will need to change that to 4 to 8 degress (maybe more if you go SOA). Might want to seriously consider outboarding & new spring also.
Oh yea Welcome to the sickness!
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 10:24 AM. |
