ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 02-26-2003, 12:02 AM
Journeyman
gmussell is an unknown quantity at this point
Default cheap bed liner
anyone interested in painting their inside or under side with bed liner,
check out sportsmansguide.com
item number
CX3X1 - 72055
rustolium brand, says there is enough to give an 8ft. bed two coats
$29.97
while you are there sign up for their weekly email specials
george
Old 02-26-2003, 04:05 PM
Walkenvol is an unknown quantity at this point
Default Re: cheap bed liner
Anyone have a bad experience with this product? I'm about to have the tub blasted and this sounds like an attractive coating for the underside, especially since rhino-liner wants $800 for the underside and inside of tub. I tend to want to trust the Rust-oleum name over some of the other consumer applied products. I contacted Rust-oleum and they faxed me a technical sheet. It's self-priming Polyamide converted epoxy with ground up tires as the agrigate. The rep on the phone said that it gets hard similar to Rhino-lining when it dries. Rust-oleum reccomends rolling/brushing it on. Anyone know if it can be sprayed with a standard spray gun?
Old 02-26-2003, 04:22 PM
NoBucks's Avatar
Carpal \'Tunnel
NoBucks is an unknown quantity at this point
From the description I'm guessing that the Rustoleum stuff is either licensed or rebadged Durabak/Herculiner bed liner. Good stuff, very tough, but not as thick as Rhinolining.
Old 02-26-2003, 04:38 PM
bigcheese's Avatar
bigcheese is an unknown quantity at this point
I can't comment on this particular product .....but,... the Rustoleum product line IS NOT a rust inhibitor. If you have rust and don't sand it off and or don't put a sealer on the rust it will come back. I found this out when painting the wifes Jeep.
So if you have rust this will NO cure it.
  #5
Old 02-26-2003, 05:27 PM
Joel - I've never seen Durabak/Herculiner applied first hand. Are those products also rolled/brushed? Can they be sprayed?
Mike - Considering that I'm having the tub blasted, would you still think some form of rust inhibitor would be required?
  #6
Old 02-26-2003, 05:58 PM
NoBucks's Avatar
Carpal \'Tunnel
Yes, it can be applied by roller, brush, or spray, and when it dries it's very rubbery, but not as easily cut as Rhinoliner.
My write-up on it is here: http://home.off-road.com/~nobucks/durabak.html
  #7
Old 02-27-2003, 09:07 AM
bigcheese's Avatar
Yes I would recommend that. But then again it is your Jeepster.
But you can get sealer primer; by the Gallon at any PPG auto paint place. Should run about 40-60 bucks, then get the reducer 4 to 1 so you actually will have a LOT left over for other parts.
Just my $.0000001 worth / between Toad and the government That is all I can offer.
  #8
Old 02-27-2003, 02:02 PM
I found the coupon code of spg621 to get $5.00 off the order. I haven't placed the order, but it looks like it will work.
  #9
Old 02-27-2003, 08:06 PM
johnbris's Avatar
johnbris is an unknown quantity at this point
Just for info. Durabak is some high dollar stuff. I know it is not in the same class as Herculiner.
  #10
Old 02-27-2003, 09:24 PM
NoBucks's Avatar
Carpal \'Tunnel
Durabak is $100/gallon for black, $120 for colors, or at least, that's what I paid a few years ago. As far as I know, Herculiner only comes in black.
And, like someone said above, make sure you get rid of any rust before you lay the paint down, and don't get any on your hootus. [img]images/graemlins/shocked.gif[/img]
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
