ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Jeep Forums > Jeepster-American Jeepster Club
Jeepster-American Jeepster Club This board is maintained by the American Jeepster Club to support all discussions of Jeepster Commandos and Commando models of Jeeps. Please visit our club web site for more information at www.off-road.com/jeepster
Old 02-25-2003, 10:38 PM
oldtop
Default rear spring lengths
I have a 69 jeepster with the mono leaf rear spring. Are the springs on a 69 interchangeable with springs from a 73?
I would like to replace the mono spring with a multi pac spring set up. I could use the extra support from multiple (HD) springs. [img]images/graemlins/thud.gif[/img]
Thanks
Old 02-25-2003, 10:45 PM
Caver Dave's Avatar
Caver Dave is an unknown quantity at this point
Default Re: rear spring lengths
Yes
Old 02-26-2003, 12:17 AM
Journeyman
gmussell is an unknown quantity at this point
Have you found any other vehicles that can work?
I was out at the junk yard talking to my friend about just getting some main leaf to add to my mono's, I noticed he had several late model Cherokees. are they close? Somehow I have to help my suppension.
thanks for your time
george
Old 02-26-2003, 12:23 AM
Caver Dave's Avatar
I believe the late model Chero leafs are roughly 3" shy. [img]images/graemlins/frown.gif[/img]
  #5
Old 02-26-2003, 07:19 AM
Carey
Steve I have a set of rear springs out of my Jeepster you can have if you want to come get them. I'm in Nashville, TN. They aren't perfect but they can be used. The center tie bolt is broken in one but all the leaf's are there. And the rear shackles are stuck in the bushings in the spring eye. I have no use for them I went to YJ springs with custom spring mounts.
  #6
Old 02-26-2003, 09:05 AM
Journeyman
carey,
what was involved in the spring swap? Any pictures?
george
ps
whats a YJ? [img]images/graemlins/confused.gif[/img]
  #7
Old 02-26-2003, 02:28 PM
Carey
YJ is a (YJ) Wrangler 1987 to 1995 the 1997 to present is a TJ Wrangler. There was no 1996 model produced by Jeep.
I had to fabricate new rear mounts 10" in front of the rear crossmember. They are similar to making mounts to move the front springs outboard of the frame. I haven't completed me jeepster yet so I just hope it work as well as I think. I used 2-1/2" YJ lift springs with a spring over.
frame modifications
body on frame
  #8
Old 02-26-2003, 02:38 PM
Caver Dave's Avatar
Carey,
How much do you anticipate them flattening once the engine/tranny/TC are installed? I was thinking of going with some 1"-2" YJ leafs, but good grief! I don't have 38"s to clear!
  #9
Old 02-26-2003, 04:34 PM
bigcheese's Avatar
bigcheese is an unknown quantity at this point
BUT it would be cool if you did!!!
  #10
Old 02-26-2003, 07:13 PM
Carey
[img]images/graemlins/grin.gif[/img]Dave, that pic is with 36's I designed and set it up to clear 38's that's why it looks like so much clearance. 38's is the average my club runs. The rear springs are YJ Rancho 2-1/2" 4 leaf lift springs. The front springs are stock YJ 4 leaf with a CJ 2-1/2" add-a-leaf for a total of 5 leafs. I do expect some flattening out but I believe they will still have adequate clearance for the 36's. The rear probably will not drop a whole lot. I have all the spare parts stored inside the body I even had a D44 front housing, two hoods, two fender, two grills, two radiators and a lot of extra steel stored inside the tub with no effect on the height. It barely moved with all 240 lbs I had, I'm down to 208 now, on the front end. If I had not done the shackle reversal I would not have to put the Hi-Steer on it. I hope to have the drive train in by the end of March, if the weather will ever break, then I can see how it effects the clearance.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
