dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Jeepster-American Jeepster Club Please also visit our club web site for more information at http://www.americanjeepsterclub.org/ |
07-31-2002, 11:55 PM
|  | Keyboard Implanted | | Join Date: Sep 1999 Location: Vancouver, WA, near Portland, OR
| | Re: hei dist conversion tomorrow...one ques. though...
Here's a pic of a properly installed odd-fire HEI in a 225.
08-01-2002, 07:22 PM
Looks great...but how do you have your fuel lines run? I can't really see from the pic. I am standing here wondering how I am going to reroute mine. It just so happens I have an inline filter right where the new HEI goes...!
08-01-2002, 07:49 PM
i just replaced mine with a rubber fuel hose, i thought i would have vapor locking problem but i havent yet. id post a picture but i dont have one.
08-02-2002, 12:08 AM
| | Way Outta Control | | Join Date: Sep 1999 Location: usa
You may want to consider an electric pusher pump at the tank instead of trying to get the fuel lines past it. I don't like fuel lines so close to the manifold, rubber or steel.
I used one of the cheapie electric pumps from Kragen, about $30. There's 2 kinds, get the low pressure one - I think it's 3-5 lbs, not the 5-7 lbs.
It's so cheap I bought 2, one as a spare for under the seat.
So far the spare has come in handy twice - not for me, but for trail fixing other folks.
08-02-2002, 01:30 PM
Thanks RRich, I was just thinking of doing that myself. Did you run the line up the passenger side frame rail? Is there anyway to insulate the line?
08-02-2002, 01:43 PM
I don't think I ran a new line, just hooked into it in back right in front of the tank and rerouted it from behind the engine to the carb. Made a bracket to mount the pump on the frame high up out of the way, isolated the pump from the bracket with rubber bushings so it doesn't make noise.
Also I put an in-line filter by the carb too. Plugged off the return line as well. |
08-03-2002, 02:12 AM
71MtnJeepster:
Sorry for the delay, but I didn't get to check the fuel line until today. From what I can tell, it's the stock routing up the back side of the engine from the passenger side frame rail. What's different for now is a previous owner removed the mechanical fuel pump due to a home-brewed power steering pump bracket that got in the way of it, (I believe that this rig originally had manual Saginaw and was later converted to power Saginaw). A block-off plate was in place when I picked it up and an electric fuel pump was being used. I have since purchased a proper p/s bracket and added a mechanical fuel pump. A fuel line was bent to snake from the pump up and under the upper radiator hose, I think comming up on the passenger side. It will connect to a hose, then fuel filter then hose to the carb. I will have to figure what to do with the fuel line to get it to the mechanical fuel pump. I had a fuel line put on the driver side and go to the pump on my '66. Not sure if the '71 will keep original routing over top of engine to fuel pump then back up to carb though.
08-04-2002, 10:10 AM
ok guys, I am getting close to being finished...I have decided to install and electric fuel pump, and all I have left to do is to wire it and I will be finished (I hope).
Ok, now for the problems I have had with the HEI conversion:
When you guys said it was tight clearance with the new HEI cap and the manifold, YOU WEREN'T KIDDIN'! I can BARELY move the distributor at all due to the cap hold down post, but it looks like I can't grind anymore on the manifold. I hope I am really close on the timing, otherwise I'll have to rearrange the cap to a different location.
Ok, problem 2. This may sound stupid, but where/how to I wire up the 3 connector pigtail coming out of the base of the new HEI? I couldn't find instructions anywhere...and I also have a red wire that came off the old coil and went to the starter...where does it go? I will post pics when I get done...thanks for all your help!
Mark
08-04-2002, 05:27 PM
Take a close look underneath the "lump" on the side of the cap, under where it says Batt and Tach or DEC.
Close in to the cap under the lump is where the connector from the base goes.
The wire from the old coil to the starter solenoid - ditch it, no longer needed.
Be sure to bypass or eliminate the ignition resistor, the HEI needs a full 12 volts.
I think if the distributor is clocked in a slightly different position you have more adjustment, not much, but enough. | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 05:44 AM. |
