O/T How do I remove carpet glue from my car? - Off-Road Forums & Discussion Groups
Old 12-14-2001, 10:02 PM
Default O/T How do I remove carpet glue from my car?
I've removed the carpeting from my VW Rabbit and want to remove the glue from the floor. I've tried Goof Off, paint stripper, brake cleaner, heat, everything I can think of. Anyone had any luck removing this stuff? I was thinking aircraft stripper might work. At least the Jeep didn't have this crap in it!
84 CJ7,AMC 360,dual lockers,33" Swampers,5 spd
Old 12-14-2001, 10:07 PM
Infernozx's Avatar
Carpal \'Tunnel
Infernozx is an unknown quantity at this point
Default Re: O/T How do I remove carpet glue from my car?
Acetone? Paint Thinner? Spirit of Ceddar?
With the carpet removed can you really fit 33's under your JEEP?
Old 12-14-2001, 10:21 PM
I just tried Acetone. It only works when there is just the glue residue left. It won't cut through the glue.
Old 12-15-2001, 01:42 AM
YJAroundTheWorld is an unknown quantity at this point
Two Steps:
1: Prepare Scissors,
2: Cut Carpet.
Good luck buddy, from my expierience that stuff is hell to remove!
=-Ben
94 ZJ - Grocery Getter, Work Commuter.
89 FSJ - Work in progress.
87 YJ - 5' of lift, Xterrains 33's. ARB Snorkel.
48 CJ2A - Lawn Sculpture.
  #5
Old 12-15-2001, 05:54 AM
bluseman2a is an unknown quantity at this point
I would try Xylene first. Air craft stripper will certainly do it, but will also take off any paint down to the metal.
  #6
Old 12-15-2001, 06:50 AM
sas87yj
why remove it? what are you going to put down to replace the carpet- more carpet?
  #7
Old 12-15-2001, 02:53 PM
When I ripped the carpet out of my CJ, I tried enough stuff to start chemical warfare. None of it worked. My 4.5" grinder with a sanding disc did though.
Type 6-"Woodlands" '82 CJ'7
Type 2-"Occasional 'froader" '96 ZJ
  #8
Old 12-16-2001, 09:08 PM
I found that using a putty knife and a small blow torch to heat it worked well to scrape most of the glue off. I can then use acetone or whatever to clean the residue. The plan is to paint the interior with Herculiner. Thanks for the ideas.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
