Hot wire a jeep?? - Off-Road Forums & Discussion Groups
Old 09-08-2001, 11:21 PM
Default Hot wire a jeep??
Ok, how do you hotwire a jeep? Other than the power and starter wire, which two wires do you connect? Basically what I need to know is how to keep the ignition in the on position whithout the key. Thanks.
Old 09-08-2001, 11:30 PM
3jeepguy's Avatar
3jeepguy is an unknown quantity at this point
Default Re: Hot wire a jeep??
get a schematic for the jeep (like in a haynes manual) then reach up under the dash and unplug the two plugs that mount to the side of the steering column and wire up some switches and go
jeep the first 4 wheel drive the only 4 wheel drive
Old 09-08-2001, 11:42 PM
I kind of need to know how to do it from under the hood. How would I do it from a starter solenoid?
Old 09-09-2001, 08:43 AM
ozarkjeep's Avatar
ozarkjeep is an unknown quantity at this point
if youve got a locked steering wheel it wont do you any good.
2 sides of the solenoid, each has large and small wires.
run a wire from +Bat to the second largest red wire on the solenoid. ( the side not connected to the battery)
then jump the 2 large bolts with a screwdriver ( this will turn teh starter)
be careful, have a fire extinguisher handy and you should no that a shorted battery can/might explode in your face peppering you with acid.
Make sure its in Nuetral
OzarkJeep
"Bare foot girls, dancing in the moon light..."
  #5
Old 09-09-2001, 08:46 AM
sloop is an unknown quantity at this point
On my Jeep, I can jump the starter solenoid by using a screwdriver from the battery post on the solenoid to the small post on top next to it.
Mark
83 CJ-7 and 76 CJ-7 with stuff
  #6
Old 09-09-2001, 12:52 PM
run a wire from the + side of battery to the + terminal of the coil then jump the starter selenoid as described above
There are 2 ways to learn your own mistakes and other peoples mistakes
  #7
Old 09-09-2001, 12:59 PM
dschwab9's Avatar
Pooh-Bah
dschwab9 is an unknown quantity at this point
This is scary - all this talk about Hot Wirin'! I better make sure I don't park my Jeep near any of you guys [img]/wwwthreads_images/icons/smile.gif[/img]
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
  #8
Old 09-09-2001, 06:52 PM
thanks for the help.
  #9
Old 09-10-2001, 01:30 AM
Infernozx's Avatar
Carpal \'Tunnel
Infernozx is an unknown quantity at this point
My Jeep you just turn the key cylinder, key or no key it starts right up.
[b]Proud owner of the first "trans-Oz" four wheel drive[b] (We took the "Yellow Brick" trail.)
  #10
Old 09-10-2001, 02:41 AM
dschwab9's Avatar
Pooh-Bah
Mine won't start without the key, but you can pull the key out with it running and the steering wheel lock only works about 50% of the time [img]/wwwthreads_images/icons/smile.gif[/img]
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
