Vapor Lock, how do you cure it? - Off-Road Forums & Discussion Groups
Old 10-23-2000, 01:27 PM
Default Vapor Lock, how do you cure it?
My CJ7's 360 is suffering from vapor lock , what are some ways to cure this?
Could I wrap the fuel lines with some heat resistant material?
Install an electric fuel pump?
Any info is most appreciated.
luvmud@yahoo.com
Old 10-23-2000, 01:46 PM
greencj7 is an unknown quantity at this point
Default Re: Vapor Lock, how do you cure it?
My guess is that if you have headers on the 360, they're ending up pretty close to the fuel line. Try moving the line farther away from the source of the heat. If it's a ways away from the header, check along the frame where the fuel line runs. If the exhaust comes close, there's the source of your problem. Don't forget to check from the fuel pump to the carb. I believe Summit sells insulating stuff for fuel line, if you need to go that route.
Ken
Old 10-23-2000, 01:51 PM
I was fighting that with my 350 swap as well. I ended up running new fuel lines inside the frame tubing instead of parallel to the exhaust tubing on the inboard side of the frame and installed a return line. When I first did my swap, wasn't running a return. Without a return, the fuel just sits in the lines waiting to be used. With a return, the warm fuel constantly circulates back to the tank where it mixes with the cool fuel there and gets recycled. I also put a heat shield under the carb. It runs great on hot days now. Much better than before.
Jason '87YJ
"If you didn't build it, it isn't yours . . ."
Old 10-23-2000, 03:05 PM
jeepsternaut's Avatar
Journeyman
jeepsternaut is an unknown quantity at this point
Need some help understanding vapor lock to help diagnose problems of my own...I know what vapor lock is, but is your jeep completely cutting out? or just running poorly (hesitating)when you give it gas? also, is vapor lock more of a problem at higher altitudes? I was getting some hesitation out of mine and I suspected vapor lock at one point in time...but have since, I think, curred that problem. With my 360 the line still runs along the right side and over the timing gear cover to the pump.
78 CJ5 w/360
"measure it with a micrometer, mark it with chalk, and cut it with an axe"
  #5
Old 10-23-2000, 05:16 PM
Thanks for the responses! I dont have headers just the stock manifolds.
My Jeep runs great cold but when it warms up runs like crud (hesitation,like only 7 or 8 cylinders are working)
I installed a clear fuel filter when cold is half full of gas but when warm is almost empty (telltale sign of vapor lock I ma told)
I kept the gas line running on the passenger side,then routed it under the engine (along crossmemeber) up to the fuel pump, from the fule pump it goes to a new fuel pressure gauge,fuel filter then to the carb.....I used to run the line up over the right side of the engine to the pump but thought routed it under the engine would keep it cooler.
  #6
Old 10-23-2000, 06:35 PM
InfantryYJ's Avatar
InfantryYJ is an unknown quantity at this point
I always thought "Vapor Lock" was something you did to a woman.[img]/wwwthreads_images/icons/laugh.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img]
I may not like what you say, but I'll defend to the death your right to say it.
Semper Jeep
  #7
Old 10-23-2000, 07:32 PM
I'm sure this isn't the cause of the problem, but you may want to take off the clear fuel filter and use a normal one. The clear filters often have moisture get in around the caps on either end. That's bad.
canis
'82 CJ-7/360/727/D300/M.O.R.E. shackles and lots of ideas!
Have you kissed your JEEP lately?
  #8
Old 10-25-2000, 09:18 AM
CJDave is an unknown quantity at this point
[img]/wwwthreads_images/icons/smile.gif[/img] Vapor lock can be caused....or made worse.....by (1) pinhole leaks in the fuel line to the tank which let the fuel pump suck in air and as the negative pressure acts on the air the bubbles increase in size. At higher altitudes the gas bubbles easier so it is worse. (2) Heat which boils the fuel in the fuel lines. Like on a VW engine there is only about ONE PLACE where you can put the fuel supply line that is cool enough, and that line needs to be steel not black rubber. So protect the lines from heat; use steel whenever possible; and check for pinholes.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
