Offenhauser 4-BBL. Intake Manifold, for I6 wrangler? - Off-Road Forums & Discussion Groups
Old 12-16-1999, 12:29 AM
Default Offenhauser 4-BBL. Intake Manifold, for I6 wrangler?
I was just curious if anybody knew anything about them, I don't know much at all, I just found it at JC Whitney's site when I was bored.... I quess it works with the 258 I6, and allows you to use a 4 bbl carb.... I don't know, just lookin for ways to make my engine any better, lol...
Ohh yeah, here's the link to the url were I found it,
http://www.jcwhitney.com/item.jhtml?ITEMID=6144
Thanks a lot,
Peter Lombard
'89 Wrangler
Old 12-16-1999, 12:55 AM
Default Ohh yeah one more Q....
If it is any good, what type of carb should I use, the site says it fits a standard 4bbl Holley carb, but I don't know much about carbs so, what is a standard holley carb, lol....
Thanks a lot,
Peter Lombardi
'89 YJ
Old 12-16-1999, 01:03 AM
Default Re: Ohh yeah one more Q....
offy makes very good manifolds. standard holly flange refers to the opening and bolt pattern it uses. on a 258 you need to stay under 500 cfm on a carb. i would run a 390cfm holley four bbl or a motorcraft 2bbl.
dan
[img]/wwwthreads_images/icons/smile.gif[/img]<font color=blue>let it snow<font color=blue>[img]/wwwthreads_images/icons/smile.gif[/img]
Old 12-16-1999, 01:24 AM
Tim's Avatar
Tim Tim is offline
Tim is an unknown quantity at this point
Default Re: Offenhauser 4-BBL. Intake Manifold, for I6 wrangler?
If you look the ad over closely, you'll detect an oxymoron. "Dramatically improves low-end torque, fuel economy and engine performance from 2,500 to 7,000 RPM." You can't possibly do that since low-end is 2500 rpm and below. For the record, unless one is racing or just has really low gearing, 90 plus percent of the time is spent at 2500 rpm and below. You can't gain anything if you don't operate in the intended range it was designed for. In fact, you'll stand to lose in the everyday 2500 rpm and below range. I tried to cross this manifold in my Offy catalog, but JC doesn't use Offy's #'s. Since they only make two different intakes for the AMC I-6, I suspect it's their "C" series manifold. Their other manifold, the "Dual Port" is designed as a dual plane intake for improvements in the 1000-5000 rpm range, right where the majority of us operate. Before I replaced my Buick 225 V-6 with a Buick 252/4.1L V-6, I was running the Offy Dual Port intake, Holly 390 cfm 4 bbl and HEI distributor. It was a very nice combination once it was properly set up. I suspect the same combination on the AMC I-6 would prove likewise. Don't waste your time with headers as they too don't benefit until above 3500 rpm. Stock manifold with good single exhaust, (Flowmaster or the like), exiting behind rear wheel should give the best benefit unless you intend to race most of the time. Good luck.
Tim
'66 Jeepster Commando w/Buick 252/4.1L V-6
'70 Wagoneer w/Buick 350 V-8
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
